03-07-2016, 07:16 AM | #1 |
Drives: 2013 AGM ZL1 BELLA* Join Date: Jan 2011
Manual Trans Fluid
What are you guys running or suggesting. I am going through and changing all the fluids on the ride, wondering what you guys are running in the Manual Trans?
I did some searching and Royal Purple seems to pop up. I'm kinda between Royal Purple or GM stuff. Just wanted to gather your experineces with this. Thanks
Roto Fab CAI, Roto Fab Big Gulp, Jokerz ported SC/Snout, LS7 TB ported, ATI Balancer, 28%(10") Lower Pulley, 2" Headers, No Cats,Forza 3way, E85 Flex Fuel sensor , ID850 injectors,, BTR Stage 3, Ron Davis HX, Mighty Mouse CC, APR Splitter, Aero Sports Concepts Splitter Kit, Showstoppers CarbonFiber wicker bill, MRR Wheels. 720rwhp/690tq on 93, 762rwhp E85.
2013 AGM ZL1 Bella* 2010 MGM Toyota Tacoma 2010 CGM SS (Traded) 1996 Black SS (Sold) |
03-07-2016, 07:38 AM | #2 |
Drives: 2014 1SS/RS Join Date: Apr 2015
I switched to this in the first few thousand miles: http://www.amazon.com/gp/product/B00...ilpage_o03_s00
Felt much smoother, so far been good. Otherwise I've heard the Royal Purple is good too!
03-07-2016, 10:22 AM | #3 |
Drives: '16 Z06/Z07, '15 Z/28,1972 Stingray Join Date: Feb 2013
Factory fill..AC Delco!
Makes a huge difference changing fluids after break in. Don't forget the rear end fluid as well.
2015 Z/28 #642 Black Bad Ass
03-07-2016, 12:30 PM | #4 |
Go fast, please.
I did the differential fluid and the fluid that was in there looked really dirty after about 2k miles. I didn't do the transmission though, did you guys notice a difference replacing the stock fluid with fresh stock fluid?
03-07-2016, 12:56 PM | #5 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
I run Royal Purple and I track my car....no issues so far.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
03-07-2016, 02:59 PM | #6 |
I was doing both trans and rear diff... Was going to stick with AC Delco on the rear but was looking closer at royal purple for the trans.
03-07-2016, 04:05 PM | #7 |
Go fast, please.
Anyone know the part number for the AC Delco stock manual transmission fluid?
03-07-2016, 06:27 PM | #8 |
Drives: 2017 ZL1 Garnet Red Join Date: Feb 2015
I used Amsoil and it made the trans shift smooth.
03-07-2016, 07:33 PM | #9 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
I spoke with the Tremec tech rep at Autorama last week and he stated just make sure it's a full synthetic.
03-07-2016, 08:21 PM | #10 | |
Drives: 2015 Camaro ZL1 (red hot) Join Date: Dec 2014
03-07-2016, 08:33 PM | #11 |
Absolutely...eliminated the resistance when up and down shifting. Highly recommend it!!
03-08-2016, 05:53 AM | #12 |
Which Tran fluid did you end up changing to?
03-08-2016, 05:55 AM | #13 | |
03-09-2016, 10:35 AM | #14 |
As an update on this subject, I gave Royal Purple a call getting a few details on their trans fluid, decided to ask the tech while I had him on the phone about the rear end fluid. Apparently Royal Purple already has the additive needed for our Limited Slip added to the fluid already. I didn't know this ha, maybe some already knew but either way I'm going Royal Purple for both trans and Rear. I will update on this after I change everything out.
