Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > Engine | Exhaust | Bolt-On | Drivetrain Modifications
Old 03-07-2016, 07:16 AM   #1
rjs2010SS
rjs2010SS's Avatar
Drives: 2013 AGM ZL1 BELLA*
Manual Trans Fluid
What are you guys running or suggesting. I am going through and changing all the fluids on the ride, wondering what you guys are running in the Manual Trans?
I did some searching and Royal Purple seems to pop up. I'm kinda between Royal Purple or GM stuff. Just wanted to gather your experineces with this. Thanks
Roto Fab CAI, Roto Fab Big Gulp, Jokerz ported SC/Snout, LS7 TB ported, ATI Balancer, 28%(10") Lower Pulley, 2" Headers, No Cats,Forza 3way, E85 Flex Fuel sensor , ID850 injectors,, BTR Stage 3, Ron Davis HX, Mighty Mouse CC, APR Splitter, Aero Sports Concepts Splitter Kit, Showstoppers CarbonFiber wicker bill, MRR Wheels. 720rwhp/690tq on 93, 762rwhp E85.
2013 AGM ZL1 Bella*
2010 MGM Toyota Tacoma
2010 CGM SS (Traded)
1996 Black SS (Sold)
rjs2010SS is offline   Reply With Quote
Old 03-07-2016, 07:38 AM   #2
WisTech
Drives: 2014 1SS/RS
I switched to this in the first few thousand miles: http://www.amazon.com/gp/product/B00...ilpage_o03_s00
Felt much smoother, so far been good. Otherwise I've heard the Royal Purple is good too!
WisTech is offline   Reply With Quote
Old 03-07-2016, 10:22 AM   #3
Shark72
Shark72's Avatar
Drives: '16 Z06/Z07, '15 Z/28,1972 Stingray
Factory fill..AC Delco!
Makes a huge difference changing fluids after break in.
Don't forget the rear end fluid as well.
2015 Z/28 #642 Black Bad Ass
Shark72 is offline   Reply With Quote
Old 03-07-2016, 12:30 PM   #4
jayno20
Go fast, please.
jayno20's Avatar
Drives: 2019 Corvette ZR1
I did the differential fluid and the fluid that was in there looked really dirty after about 2k miles. I didn't do the transmission though, did you guys notice a difference replacing the stock fluid with fresh stock fluid?
jayno20 is offline   Reply With Quote
Old 03-07-2016, 12:56 PM   #5
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
I run Royal Purple and I track my car....no issues so far.
Mods:
Old 03-07-2016, 02:59 PM   #6
rjs2010SS
rjs2010SS's Avatar
I was doing both trans and rear diff... Was going to stick with AC Delco on the rear but was looking closer at royal purple for the trans.
2013 AGM ZL1 Bella*
Old 03-07-2016, 04:05 PM   #7
jayno20
Go fast, please.
jayno20's Avatar
Anyone know the part number for the AC Delco stock manual transmission fluid?
Old 03-07-2016, 06:27 PM   #8
NW Sam
NW Sam's Avatar
Drives: 2017 ZL1 Garnet Red
I used Amsoil and it made the trans shift smooth.
NW Sam is offline   Reply With Quote
Old 03-07-2016, 07:33 PM   #9
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
I spoke with the Tremec tech rep at Autorama last week and he stated just make sure it's a full synthetic.
ZMEnow is offline   Reply With Quote
Old 03-07-2016, 08:21 PM   #10
Harley01
Drives: 2015 Camaro ZL1 (red hot)
+1!!
Harley01 is offline   Reply With Quote
Old 03-07-2016, 08:33 PM   #11
Shark72
Shark72's Avatar
Absolutely...eliminated the resistance when up and down shifting. Highly recommend it!!
Old 03-08-2016, 05:53 AM   #12
rjs2010SS
rjs2010SS's Avatar
Which Tran fluid did you end up changing to?
2013 AGM ZL1 Bella*
Old 03-08-2016, 05:55 AM   #13
rjs2010SS
rjs2010SS's Avatar
This website seems to have both Auto and Man Tans fluid. They should have the part number in the description. http://paceperformance.com/i-6239257...l-3-32-oz.html
2013 AGM ZL1 Bella*
Old 03-09-2016, 10:35 AM   #14
rjs2010SS
rjs2010SS's Avatar
As an update on this subject, I gave Royal Purple a call getting a few details on their trans fluid, decided to ask the tech while I had him on the phone about the rear end fluid. Apparently Royal Purple already has the additive needed for our Limited Slip added to the fluid already. I didn't know this ha, maybe some already knew but either way I'm going Royal Purple for both trans and Rear. I will update on this after I change everything out.
2013 AGM ZL1 Bella*
