01-19-2016, 04:15 PM | #15 | |
Drives: 2011 2ss/rs black with white rally Join Date: Apr 2012
Just the twin turbos until I figure out how the car acts. I have the booster pump but I am keeping my eyes out for a ZL1 pump. I guess if a number is what I was shooting for it would be 650rwhp ish, but I will probably just max out what I have when I have it
01-20-2016, 09:09 AM | #16 |
Drives: 2010 SS/RS Supercharged 427 Build Join Date: Nov 2010
Sounds like a great winter project! Good luck with the install!
01-20-2016, 09:33 AM | #17 |
Sweet!!!!!
"How do u keep it under the speed limit? YOU CANT HAHAHAHA" |
03-01-2016, 03:01 AM | #18 |
turbos are in
03-01-2016, 01:00 PM | #19 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
sweet, how long before your tune and drive it?
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
03-01-2016, 01:33 PM | #20 |
Waiting on Kevin to help me out with the email tune, then off to Nikeys in St. Charles for tweaking, thats the plan anyways. hope to drive it by next week or so
03-01-2016, 01:53 PM | #21 |
Drives: Black L99 2SS/RS Join Date: Mar 2014
You are a very patient man, the anticipation would be eating me alive.
congrats!! If you don't mind me asking, how much did everything total run you? |
03-01-2016, 03:18 PM | #22 |
Drives: 2014 1SS/RS, 2018 Silverado CC Join Date: Apr 2014
+1 on the cost?
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
03-02-2016, 12:41 AM | #23 |
lol yes the cost i think it just keeps costing but i got a great deal from Jared at JDP he did right by me!!! it all depends on what u add.
03-03-2016, 07:54 AM | #24 | |
Drives: 2014 1SS/RS Join Date: Apr 2015
03-03-2016, 05:16 PM | #25 |
yep headed there when weather permits and he can fit me in.
Car is running like a champ thank you KEVIN!! fuel system in next ZL1 pump and BAP
03-08-2016, 08:02 PM | #26 |
Drives: 2017 Garnet Red 1LE Join Date: May 2014
fuel system
you are running the kit on a stock SS pump? How much boost?
New Camaro --- 2017 SS 1LE Garnet Red -stock
Last Camaro --- 2014 2SS || 6 speed || NPP || Kooks 1 7/8 LT +Cats || Apex Catch Can || BW PTB || CAI induction || 12.99 @ 111 stock tires, 2.1 60' Old Camaro --- 94 Z28 Vert-- Miss it. |
03-31-2016, 12:21 AM | #27 |
zl1 pump and bap on 8psi 532 rwhp 526 torq
03-31-2016, 08:42 AM | #28 |
Drives: 2015 2SS Join Date: Sep 2015
