Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Sponsors Camaro Builds / Project Cars
Old 02-27-2015, 07:56 PM   #29
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Originally Posted by NicKey View Post
Good Question.
We at NicKey use "Standard" vs "SAE" TQ & HP numbers. The Standard numbers are slightly higher than SAE. The OEMs use SAE.
We use our base line to measure the effect the mods have on power.
We can display both numbers, but now use SAE. A while back we were involved with some testing for an aftermarket mfg along with some other performance shops and of the 5 shops testing, we were the only ones using the "lower" numbers. We all agreed to use the STD measurement from then on amongst the group. Later as the dyno results started to populate the Forums and magazine articles we continued to use the "STD" measurement, as a fair basis of comparison, since that is what the others were using (not Camaros).
So, STD is: 471.34hp and 441.46tq & SAE is 459.93hp and 430.91tq
Approx 2.45% difference. So when you want to compare to the OEM numbers you should use an SAE dyno measurement.
The 15% loss of power, to the rear wheels is not an exact number and it is also not linear. It is a guide and estimate. Every type of Camaro can be different. The only way to know for certain would be to pull the Z28 engine and run it on an certified Engine Dyno.
It is my opinion that the LS7 in the Z28 has been rated conservative by GM. To your point no A/C vs A/C may have a minor effect.
The Key here is to see how much more TQ & HP we achieve with this build and where it comes in on the power curve, then some real world application.
Thanks for the explanation. 459 SAE rwhp is higher than most also. Most SAE dynojet runs put the Z/28 at 440rwhp and 410rwtq. Did both cars baseline nearly the same or do you think you have a "factory freak"?
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 02-28-2015, 04:08 PM   #30
NicKey
NicKey's Avatar
Drives: Nickey Super Camaro
The dyno results are on the plus side of the our anticipated range.
NicKey is offline   Reply With Quote
Old 04-07-2015, 01:49 PM   #31
NicKey
NicKey's Avatar
NicKey Z28s
Good news. NicKey recently received one of the very first sets of Kooks Z28 headers and they fit very good, with no issues especially around the larger Z28 oil cooler.
Once again, job well done by the Team @ Kooks.
Call 630-377-1222 to oder a set of 5th gen Z28 headers.
Old 05-16-2015, 08:54 AM   #32
NicKey
NicKey's Avatar
We have on set left, which is 1-7/8th Z28 Specific with LS7 D port flanges.
Call or PM for price........no waiting!
Old 05-27-2015, 07:58 PM   #33
NicKey
NicKey's Avatar
NicKey Stage III Z28 Naturally Aspirated
Stock Z28 CAI
Kooks Headers
NicKey Stage II Cam / Kit
Ported Heads
Off road connection pipes
Fast Intake
Ported Throttle body
We still have some work to do and will install a larger throttle body, but the results thus far are looking very good.
Old 05-28-2015, 10:26 AM   #34
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
"looking very good" = "Oh hell yeah" in that sentence...
Old 05-28-2015, 02:52 PM   #35
Johnnyo1
Drives: 2011 Cyber Grey SS
Sweet
Nice job as always Stefano !
Johnnyo1 is offline   Reply With Quote
Old 06-04-2015, 06:29 PM   #36
NicKey
NicKey's Avatar
NicKey Super Camaro / Z28 #001
Old 06-04-2015, 06:34 PM   #37
NicKey
NicKey's Avatar
2
Old 06-04-2015, 06:36 PM   #38
NicKey
NicKey's Avatar
3
Old 06-04-2015, 06:38 PM   #39
NicKey
NicKey's Avatar
4
Old 06-04-2015, 06:39 PM   #40
NicKey
NicKey's Avatar
Thank you!
Old 06-04-2015, 11:32 PM   #41
WisTech
Drives: 2014 1SS/RS
Looking good!!!
WisTech is offline   Reply With Quote
Old 06-11-2015, 11:55 PM   #42
Bowtie-Bri
Bowtie-Bri's Avatar
Drives: 2013 Camaro 2SS RS Convt.
That is one of the finest Z-28's I've ever seen! Love the Nickey touch!
2013 Nickey Stage II Camaro SS Convertible #10.Black w/ Red leather interior. No Weeds Elec. Diverters, CNC ported heads, custom grind cam, upgraded fuel injectors, ZL-1 fuel pump, V-Max ported TB, Red Magnuson Super Charger with rear cog drive, upgraded rear axles good for 1400Hp, 3:45 gears, Tremec 6 spd., Pedders adj. coil overs, Phadt ZL-spec swaybars, 800Hp at the crank, 670RWHP, 613ft.lbs. torq. @ 11lbs. boost. SOLD!!!
Bowtie-Bri is offline   Reply With Quote
