BeckyD @ James Martin Chevy
Old 11-28-2023, 04:33 PM   #57
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
old thread alert
Originally Posted by carguy55 View Post
Been loving the Mobil1 ATF on track. No more 2-3 shift issues.
Mike, do you use Mobil 1 Synthetic LV ATF HP? There are several synthetic options
h018871 is offline   Reply With Quote
Old 12-16-2023, 10:41 PM   #58
mtdwye0
Drives: 2023 2SS 1LE
Would Redline D6 ATF be better than D4?
mtdwye0 is offline   Reply With Quote
Old 12-24-2023, 06:34 AM   #59
OneLapWonder
Drives: 2008 Audi RS4
I recently changed using ACDelco 10-4033.
1-2 shift is easier to grind since it gives you a false sense of getting fully into the gate and you get the grind when you let off the clutch.
2012 Lexus CT200h Premium Navi
2008 Audi RS4
2004 Audi S4
2018 Chebby Camaro ZLE HMB
OneLapWonder is offline   Reply With Quote
Old 12-24-2023, 04:23 PM   #60
booyaa56
booyaa56's Avatar
Drives: 2017 Camaro 1LE
Originally Posted by AZ_1LE View Post
Amsoil ATF Signature Series. Fantastic improvement in shifter smoothness.
AZ_1LE which one the blue or red option?
booyaa56 is offline   Reply With Quote
Old 01-05-2024, 11:43 PM   #61
WishfulSS
Drives: 17 Volt, 20 Mustang, 2015 Boxster S
Redline oil recommends the D4 for our cars. I will be using Redline for the trans as I used MTL in my 1997 M3 that was at 207K miles with the original tranny including about 1800 autocross runs.
Question: Does anyone change out the GM fluid for Redline before they get to the 15 hours of track time? A pre-emptive change? Thinking of changing at 1500 miles with the differential.
WishfulSS is offline   Reply With Quote
Old 03-27-2024, 06:33 PM   #62
avarshav
avarshav's Avatar
Drives: 2020 SS 1LE 6M, 2019 GMC Canyon SLT
how often do you guys change the manual tranny fluid? I have 8k miles on my 20 ss 1le, still on the original factory fluid. I dont drive it much obviously, and never track it, just spin around town a few times a week.
Can't really go by the owners manual on this. For example, it says you don't need to change the rear diff fluid for a while, but based on this board, I changed mine twice already, and it really needed it, and now I do it every year regardless. Haven't thought of doing the manual trans fluid yet, but now I'm thinking....
avarshav is offline   Reply With Quote
Old 03-27-2024, 08:08 PM   #63
TrackClub
TrackClub's Avatar
Drives: 2020 SS 1LE (previous: 2017 SS 1LE)
The diff defo needs a break in period, but the tranny doesnt, so very different considerations here. However, I would change the tranny fluid based on the fact, that it is now 4 yrs old. Hope this helps. Cheers!
TrackClub is offline   Reply With Quote
Old 03-27-2024, 08:16 PM   #64
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
I'm doing an annual change for my diff and tranny, but I am putting about 8 on the car each year, with lots of autocross runs and 2-3 track days per year. It definitely shifts better with fresh fluid in it.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
