01-14-2017, 07:50 PM | #1 |
Drives: G5.R Join Date: Sep 2010
New Design Camber Plates Poll
EDIT 1-15-17 Hey guys I add a poll at the top of the thread to make it easier to vote. Our desire is to make the best product available to the community. Your reply helps us accomplish our goal. So thank you in advance for the feed back!
Hey guys, we just finished the camber plates for the Gen 6 Camaro. While we were at it, we figured we would also re-engineer our gen 5. There's several benefits to the new design. I will posting more info on our Facebook page once we get a moment. We have over 30 other suspension components in line for production for the 5th gen market, so subscribe for updates. In the meantime, I wanted to get your thoughts on which ones you guys like best. Thanks for the feedback. Justin OPTION 1: Flat top surface OPTION 2: Machined pockets Sneak peak at our new roller thrust bearing design and housing. This is replacing the previous design with a ball bearing. Much better design to handle loads. Over a ton of metal waiting to get machined into Gen 5 parts. Few pics of our gen 6 prototype plates. Already started production. All the parts will be either anodized or nickle plated. These will offer the option of lowering the front a from a 1/4" or 1/2" without losing any travel. Last edited by Moreno1; 01-15-2017 at 09:37 AM. |
01-14-2017, 08:22 PM | #2 |
Drives: Z/28 Join Date: Oct 2015
Will there be a ride height increase?
01-14-2017, 08:29 PM | #3 |
This pic is showing the interference when using the factory spring isolator. This is what forced us to raise the ride height 5mm with our last design. The new design will replace the isolator all together thereby allowing us to keep them at factory height.
01-14-2017, 08:31 PM | #4 |
Drives: '14 1LE Join Date: Nov 2013
Option 2
01-14-2017, 08:50 PM | #5 |
01-15-2017, 08:28 AM | #6 |
Drives: 2015 camaro z28 Join Date: Feb 2016
I like option 1 just looks stronger to me. How much will these be selling for?
01-15-2017, 09:35 AM | #7 |
01-15-2017, 09:38 AM | #8 |
01-15-2017, 09:54 AM | #9 |
thanks I will be watching for the sale. I believe the flat would be better and voted that way because I believe all of those extra holes will just collect dust and dirt for the guys that clean under the hood means more work.
Do you guys sell any rear solid sub frame bushings for the z28 |
01-15-2017, 12:28 PM | #10 |
Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
Option 1.
Keep them solid and strong.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
01-15-2017, 01:57 PM | #11 |
Can I change my answer?
01-15-2017, 04:49 PM | #12 |
Flat top with new style roller bearing to eliminate the ride height increase. Or offer a roller bearing conversion kit for existing camber plates.
01-15-2017, 05:07 PM | #13 |
All good points! thanks for the feedback guys
We have done stress analysis on both models and they have shown that stress concentrates around the bolt holes. They do not take any suspension loads, only bolt torque load from clamping the strut tower. While the first design is definitely stronger overall, both designs are comfortably under the yield point in the pocket areas! The dust/dirt concern is a good point! taking these all into consideration! |
01-15-2017, 08:19 PM | #14 |
Not just for the Z28 right???
Orange Krush II
