10-09-2008, 08:08 PM | #1 |
Drives: 2010 Camaro SS LS3 Join Date: Dec 2007
DTC'S
Anyone have or can guide me to some schematics. I have the following codes:
26- Evap Purge Circuit 27-Egr Sol. Circuit 77-Fan 1 Circuit I have a 95 z28. I did all the basic checks-Fuses,connectors,ect. Something tells me they are all related. When I clear the codes they all come back together right away. Need to start tracing the wires.Thanks! |
10-09-2008, 08:39 PM | #2 | ||
Truth Enforcer
Drives: anything I can get my hands on Join Date: Sep 2006
clean out your evap purge solenoid
bottom left picture in this diagram. take a small shopvac and pull the purge lines and suck the crap out of them. they get clogged over time and mess stuff up http://shbox.com/1/evap_system.jpg http://shbox.com/1/evap_sol.jpg your EGR valve is probably worn. fire up the motor, once its warmed up, reach behind the intake to the EGR valve and depress the valve inside the EGR valve, if the motor rpm/sound doesnt change at all, then you need to replace the valve. also check the vacuum line for the egr solenoid as well http://shbox.com/1/opti_vacuum_conn.jpg http://shbox.com/1/egr1.jpg for the fan, replace the relay in the fuse box under the hood.
A group as a whole tends to be smarter than the smartest person in that group until one jackass convinces everyone otherwise. Quote:
10-09-2008, 08:46 PM | #3 |
I will give it a try. Thanks!
10-09-2008, 09:00 PM | #4 | ||
Truth Enforcer
sure thing.
thats what im here for. and if you want some reading material about your car and various things LT1 wise www.shbox.com www.zmydust.com www.projectlt10.com read it.... know it.... live it.... love it.... read it again...lol
10-11-2008, 03:39 PM | #5 | ||
Truth Enforcer
any updates?
11-18-2008, 04:23 PM | #6 |
Drives: '67 Camaro ZZ4 & 2010 IOM 2SS Join Date: Oct 2008
You guys are way too cool! Never seen so many willing to assist with no strings attached!!!
If I can ever be of assistance with a 1st gen, let me know. I'm not trolling the 4th gen forum, I have a 99 Z-28 also. Posted photos of my '67 ove in the 1st gen area. I have a 2SS/RS orange, orange int, hurst ordered. |
