10-06-2008, 04:18 PM | #1 |
Drives: 2010 Camaro SS LS3 Join Date: Dec 2007
keyless entry programming
I have a 95 Camaro and want to program another key fob. Anyone know the procedure?
10-06-2008, 04:25 PM | #2 |
I don't have the 1995 - this is for a 1996, you could try it...
1. Turn the ignition switch to the OFF position. 2. Remove the RADIO fuse. 3. Cycle the ignition switch from the OFF position to the RUN position (as far as you can go without cranking the engine) 3 times within 5 second ending in the RUN position. The vehicle will verify entry into the programming mode by locking then unlocking the door locks. 4. Press and hold both the LOCK and UNLOCK buttons on the first transmitter for approximately 15 seconds. The vehicle will verify programming by locking then unlocking the door locks. Your new remote has been accepted and all existing remote codes have been erased. 5. Repeat the previous step for each additional transmitter (including any existing transmitters). You may program up to 4 transmitters. This must be done before the RADIO fuse is reinstalled. 6. Place the ignition switch in the OFF position. IMPORTANT: The remote keyless entry system will not be operational if the radio fuse is open. 7. Replace the RADIO fuse. If at any time it is necessary to restart the procedure, turn the ignition OFF and proceed again with step number 1. |
10-07-2008, 08:09 AM | #3 |
Cool, I will try it tonight. Thanks Scotty!
10-07-2008, 09:36 AM | #4 |
Petro-sexual
WOW! Good man!!! Scotty can even be your Service Advisor
10-07-2008, 11:07 AM | #5 |
I used to be Dragoneye...
'95 and earlier are OBDI computer-systems. Any techniques used on 1996 to present vehicles probably won't work, because the newer OBDII system was instated -- so be careful. But I suppose it's worth a shot since you're on that borderline...
10-07-2008, 11:41 AM | #6 |
yep...my sources only go back to 1996.....but I furgured it was worthwhile...I'll dig a little more...
10-07-2008, 11:46 AM | #7 |
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
10-08-2008, 07:54 PM | #8 |
yup does not work just for the record. going to try yotaman96 advise. i'll keep ya posted..
10-08-2008, 08:06 PM | #9 |
ok that link did the trick. You just have to jumper #8 and #4 terminals at the dlc. Thanks people!
10-08-2008, 10:24 PM | #10 |
Similar Threads | ||||
LOL, a whole Wikipedia entry on Rice-burners | Mr. Wyndham | General Automotive + Other Cars Discussion | 8 | 12-02-2007 09:36 AM |
