11-10-2022, 01:34 AM | #1 |
fuel pump recommendations
Hey guys I'm new to the boosted life so go easy on me. I just got my new engine finished up and am now looking to the future with a pro charger. So I was wondering what I should do for the fuel pump? I plan on only going up to 750 whp and was wanting to know if anyone makes a drop in pump that will be sufficient for that kind of power? I really don't want to mess with a return line and all that in less that I have to. Thanks
11-10-2022, 08:03 AM | #2 |
This used to be the most common recommendation;
https://dsxtuning.com/collections/au...nt=58596002379 |
11-10-2022, 09:33 AM | #3 |
Drives: 2015 zl1 m6 Join Date: Jan 2020
Gonna be tough to do on a returnless system - been awhile when I researched fuel systems (so I could be wrong ) but for the power level your wanting to be at there was no drop in solution without running feed and return etc..
You could get away with turning stock feed line into return and just running a feed , if you’re planning on running e-85 - you’re gonna need a flex fuel sensor wires into your ecu too- I’m sure you probably know , e-85 pushes the fuels system .
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.7 @133.9 |
11-10-2022, 10:02 AM | #4 |
Drives: ZL1 Join Date: Dec 2016
Livernois have a drop in pump that is good for around 850 to 800 whp
https://www.livernoismotorsports.com...evrolet-camaro |
11-10-2022, 11:39 AM | #5 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
I ran a LPE twin-fuel (CTS-V pump) with a Kenne Bell boost-a-pump (BAP) for 745whp on E66 on LS3, FWIW. You can yield, maybe, 50whp less with a ZL1 pump and BAP.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates Last edited by dreksnot; 11-10-2022 at 05:55 PM. |
11-10-2022, 11:47 AM | #6 | |
And I don't think I will do E85 because it's so hard to find. I know it's the best way to go I just don't want to be stuck out in the middle of nowhere and not be able to find it.
11-10-2022, 11:49 AM | #7 |
Or maybe I'll stay under 700 whp and just go to a zl1 pump. I just don't want to start breaking stuff is the reason I don't want more then 750 whp.
11-10-2022, 03:08 PM | #8 |
zl1 pump with meth or ctsv twin pump with upgraded pumps. Or like said above dsx fuel system.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
11-10-2022, 03:55 PM | #9 |
I stand corrected lol I forogot about the livernois pumps .. I can’t remember but I was interested in livernois but ended up with a fore system for some reason
PB:10.7 @133.9 |
11-10-2022, 05:52 PM | #10 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Aeromotive a100 is what I run. Drop in replacement
11-10-2022, 06:14 PM | #11 | |
Drives: 2010 camaro ss Join Date: Aug 2021
Probably was in the same boat as me. They were on back order and I ended up with the agp turbo kit. I waited for 4-5 months with a order placed and never got it and started looking around at other options. I really liked the agp kit it reused the factory feed line as a return line and there harness was very well thought out and clean. If I remember correctly it uses the fore pump but everything else from the kit they put together. Sent from my iPhone using Tapatalk |
11-10-2022, 06:19 PM | #12 |
Do you intend on running e85? That might change things up a bit for what pump you decide to go with.
11-10-2022, 07:48 PM | #13 |
No I don't think so at this point.
11-10-2022, 07:51 PM | #14 |
Thanks guys for the recommendations I really appreciate it. I like the livernois but man that thing is expensive but that is exactly what I'm looking for.
