09-22-2022, 04:45 PM | #1 | |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
Video: Stealth Lift Pads from ZL1 Addons
I installed the new version of the ZL1 Addons lift points "Stealth Lift Points" on the "new to me" Camaro ZL1 1LE. These things are essential for any 6th Gen Camaro in my opinion. I like them better than the old version!
09-22-2022, 05:15 PM | #2 |
Drives: 2016 Camaro 2SS Join Date: Jun 2016
Nice video, thanks,
The only concern I have is whether tightening the set screws into the pinch weld could lead to an area where rust could form. Has anyone had that issue (with the old or new version)? |
09-22-2022, 05:32 PM | #3 |
Drives: 2022 LT1 Join Date: Sep 2022
My set of these (not the stealth, just the regular) came in yesterday. Will be a bit of a bitch to put them on since I don't have anything else to get the car higher off the ground, but we'll get it done.
09-22-2022, 05:39 PM | #4 |
oh it is a PITA. when i put mine on when I brought the car home. I was swearing at it cause its basically installing blind. to make things easier I should have put in place and used my jack to hold that pad while i set the screws. Holding it in place 1 arm and trying to fiddle with the other made it a bitch
2022 1SS 1LE 6M in Riverside blue
Found exact build local- ETA 7/31/22 New ETA - 7/26, 7/30, 7/31, 8/1, 8/8, 8/15, 8/21, 8/28, 9/17 8/24. IT HAS ARRIVED at the dealer 8/25- It is in the Garage ACS ZL1 Sideskirts, 20% tint, CAI Intake |
09-22-2022, 05:52 PM | #5 |
UK2019
Drives: Camaro 2017 2ss/eu spec convertible Join Date: Mar 2019
I had the same concerns about rust forming so coated the area the lift pad attaches to with underseal (to help prevent any galvanic corrosion between the aluminium pads and steel body) and made up a thin aluminium plate on the side with the set screws so that the screws themselves wouldn't damage the paint on the pinchweld but pressure would be applied. 2.5 years on they're still in situ and as tight as the day I attached them. I also used blie locktite on the screw threads
09-22-2022, 07:00 PM | #6 |
Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
I installed mine a couple of weeks ago. I used my Race Ramps to get under the car. Fairly easy install when you can see what you are doing.
2023 Summit White ZL1 M6 (delivered 10/15/23)
2019 Dodge Durango R/T (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) Last edited by ZPirate; 09-22-2022 at 08:35 PM. |
09-22-2022, 07:52 PM | #7 |
What's the difference between the stealth and the non-stealth? Is one better than the other?
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4
Range AFM Disabler | Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Footwell Lighting | Banks gauges in ZZPerformance pillar pod | Paddle shifter extensions |
09-22-2022, 08:36 PM | #8 |
The stealth version is smaller and lighter and I understand doesn't stick down as far
2019 Dodge Durango R/T (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
09-23-2022, 06:43 AM | #9 | |
09-23-2022, 12:51 PM | #10 |
Ordered a set.
09-23-2022, 01:54 PM | #11 | |
Drives: 2022 2LT RS Convertible Join Date: Apr 2021
09-23-2022, 02:15 PM | #12 |
UK2019
If I'm just using a jack (i.e. Not getting under the car) I use the lift pad. If I'm jacking the car up and putting it on jack stands, I jack it up on the bolts that hold the bracing to the pinch welds and put the stands under the lift pads. Since the lift pads protrude lower than the bolts there's less chance of contacting the rocker with the jack than using the bolts.
09-23-2022, 02:55 PM | #13 |
Drives: VOM 2022 2SS Join Date: Feb 2022
Give the guys at Jiffy Lube $20 bucks and showed them where to put them on since they have that pit right under the car.
09-23-2022, 03:00 PM | #14 |
I wish they'd let me just rent that pit for 20 minutes. Even after I have the lift pads on, I think installing this skip shift eliminator is still going to be a huge pain in the ass. I wish I just had access to some sort of lift or similar set up for that install.
