Go Back   CAMARO6 > Technical Camaro Topics > Dragstrip and Launching Discussion
BeckyD @ James Martin Chevy
Old 02-19-2022, 06:25 PM   #1
Kerry
Drives: 2019 2SS Camaro
Tire size Tall
Trying to figure out what size to go with. a 27 tall or 29 tall both the same width theirbouts. Im at about 700 wheel. For the streets of ole Mexico? ss
Kerry is offline   Reply With Quote
Old 02-19-2022, 08:07 PM   #2
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
What size wheel? If you are running 20” wheels then a 305/35/20 Nitto NT555R2 is probably you’re best bet for street traction, which is a 28” tall tire. If you’re running a 17” wheel, then a 305/45/17 will fit which is what I run at the strip and is also ~28” tall. Usually the NA guys run a 26” tall tire and PD blower guys run a 28 to help absorb the big torque hit down low.
Joshinator99 is online now   Reply With Quote
Old 03-08-2022, 06:09 PM   #3
TOSTO RACING
STOCK ELIMINATOR
TOSTO RACING's Avatar
Drives: STOCKER
I'm running a 30x9 hoosier radial slick with no issues. I'd go as tall as you can to help it hook.
5664 AA/SA
1970 NOVA
TOSTO RACING is offline   Reply With Quote
Old 03-09-2022, 07:54 AM   #4
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
So your basically running the Copo Hoosiers at 30x9. What power adder do you have to make 1340rwhp?
Old 03-09-2022, 05:53 PM   #5
TOSTO RACING
STOCK ELIMINATOR
Drives: STOCKER
Yes with a 15x10 wheel. I have a 416 ci with twin turbos and a th400. Excited to see what it'll run this year.
5664 AA/SA
1970 NOVA
Old 03-10-2022, 08:07 AM   #6
laynlo15
laynlo15's Avatar
Should be right there at 8.00s.
