01-12-2022, 09:09 PM | #1 |
Drives: 2019 2SS Camaro Join Date: Apr 2012
315 35 20 Tires
Anyone running this size and if so whats the front size?
01-15-2022, 08:00 AM | #2 |
That tire size is 28.7" in diameter, or 1" taller than the tallest tires the factory fits to any Camaro. I think it's likely to cause fitment issues.
Matt Miller
2020 SS 1LE |
01-15-2022, 09:42 AM | #3 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
On my 2016 Camaro SS I went with a taller tire when I got the car right at the start because it was winter and needed an all season tire. Every moderate bump/hump on the road would make the car bottomed out in the rear.
LT4 1.7 Supercharger snout ported & Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
01-15-2022, 09:58 AM | #4 |
Agreed and if you match that with a taller 35 front tire it will rub in the front. I had this problem. I would try 30s. If you are looking for a 30 DR Nitto has one. I run them on my LT1 in the summer for more fun.
"Democracy Dies in Darkness" |
01-18-2022, 08:37 PM | #5 |
Drives: 18 zl1 garnet red Join Date: Aug 2021
I’m running 315/30 on the rear and I would imagine the 35 would rub pretty much anytime you hit a significant bump. Mine is a 2021 1SS
01-18-2022, 09:42 PM | #6 |
Drives: SS-6-SPD Join Date: Jan 2017
01-18-2022, 09:56 PM | #7 |
01-18-2022, 09:59 PM | #8 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
01-19-2022, 12:51 PM | #9 |
I hope it is not rubbing like mine was. Check the inside of each front tire. I had to put a small spacer on.
01-19-2022, 02:16 PM | #10 |
01-19-2022, 03:22 PM | #11 |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
It really comes down to the brand of tire and their size. some fit 315 35's no issue while others go 315 30. look at the diameter of the tire and get as close to the factory size as possible to avoid stabili-trac issues.
I ran 315/30 and 285/35 on my car when on street tires.
01-19-2022, 05:47 PM | #12 |
Isn't it because you have MRR wheels with a different offset than the OEM 1LE wheels?
01-19-2022, 06:54 PM | #13 |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
295/30/20 and 305/30/20.
01-20-2022, 08:47 AM | #14 |
Question: Any issues with the wire harness on the driver side? I was considering going to a 315 on the rears myself. I did research 315's and from what I saw it may require I believe a 5mm spacer is that how yours is setup?
