08-31-2017, 07:00 PM | #1 |
Drives: 2010 2LT/RS Join Date: Mar 2015
2010 Inner door weatherstrip seal?
Wondering if anyone knew the part number for this inner door weatherstrip seal? It is right above the door sill area. It is in need of replacing. Seems when I do a search online I keep coming up with the outer door weatherstrip. Any help is appreciated. Thanks!
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
08-31-2017, 07:03 PM | #2 |
Drives: 2019 SS 2019 mustang GT Join Date: Apr 2017
I would hit up some of the dismantlers that sell stuff on eBay probably pick them up really cheap with free shipping
08-31-2017, 07:06 PM | #3 |
Good idea. Any in particular that you know of already? I know I could always ask the parts counter at the dealership, but always looking to save some $$.
2010 2LT/RS
08-31-2017, 07:19 PM | #4 |
Try to stay away from this stealerships LOL.. I'll hit up a few people that I deal with and see what I can find out for you
08-31-2017, 07:20 PM | #5 | |
Wow thanks! Sent from my iPhone using Tapatalk
2010 2LT/RS
08-31-2017, 07:43 PM | #6 |
This part correct?
08-31-2017, 07:48 PM | #7 |
The diagram shown above looks to be for a convertible. Since I have a coupe, the seal would be all in one piece that does not separate and goes around the whole inner bottom/sides and top.
2010 2LT/RS
08-31-2017, 07:57 PM | #8 |
Is it the passenger side or the driver side you're needing
08-31-2017, 07:58 PM | #9 |
Drivers
2010 2LT/RS
08-31-2017, 08:16 PM | #10 |
Check this out
08-31-2017, 08:22 PM | #11 |
Hmmm... Not sure if this would work. Looks like it has cut ends whereas my rubber seal is continuous. Not sure about the middle portion in the pic that is meatier and joined. I see you have a 2014 coupe? Can you take a look at yours and compare?
2010 2LT/RS
08-31-2017, 08:41 PM | #12 |
It also says that it fits a 2010 V6 and SS models
09-01-2017, 03:54 AM | #13 |
I'll have to take a look at mine again to compare. Will get back to you.
2010 2LT/RS
09-01-2017, 05:55 AM | #14 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
The same Weatherstrip on my "10 SS is also cut from my feet getting in and out.
It's nice to know the part is inexpensive but the labor may not be. The problem with replacing it is it"s only going to get cut again.
