AWE Tuning
Old 05-09-2022, 01:00 PM   #15
TXCSSU
Drives: 2022 ZL1 M6/Nissan Leaf
Originally Posted by EDFHOBBIES View Post
Okay... so what would a 141mph be in hp?
http://www.wallaceracing.com/Calcula...or%20Speed.php
And granted, there's most likely more to consider but essentially a Dyno is just making the calculations for you. The key is consistent numbers.
TXCSSU is offline   Reply With Quote
Old 05-09-2022, 06:25 PM   #16
ZL1Atlanta
ZL1Atlanta's Avatar
Drives: 2017 Chevrolet Camaro ZL1
The Wallace calculators have been almost spot on for my car’s, and others, weight and trap to what it made on the dyno once fully dialed in.
That said, we gained several MPH and shaved several tenths from my car from the first time it hit the track (same weight). Put it back on the dyno after a few months and it still made the same in a single 6th gear pull… So there are other variables to even just using trap speed. Best bet is to just use it as a tuning tool to compare changes against a base run. :-)
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned
ZL1Atlanta is offline   Reply With Quote
Old 05-09-2022, 10:36 PM   #17
BlaqWhole
Drives: 2017 Camaro ZL1 A10
Originally Posted by clg82 View Post
Isn't 7th gear our 1:1?
Originally Posted by arpad_m View Post
This may have been done to limit the max speed, many dynos do not like 200 mph or more.
Well 7th gear isn't exactly 1:1...it's just the gear that is closest to 1:1. As arpad said, 7th gear on a dyno puts you over 200 MPH. These dynos are rated up to 200 MPH. So there could be some questioning of the accuracy of the readings when going over that speed. On top of that a lot of shops just don't feel comfortable spinning the dyno that fast in case something breaks. Many of them won't go that high. So they stay in 6th. Typically 6th reads about 20 RWHP lower than 7th.
BlaqWhole is offline   Reply With Quote
Old 05-10-2022, 04:04 PM   #18
synolimit
Drives: 22 ZL1 1LE A10
Here I can officially join…
585hp, 581tq
MBRP race CBE
Rotofab CAI
6th gear
SAE Dynojet
synolimit is offline   Reply With Quote
Old 05-10-2022, 04:05 PM   #19
synolimit
Seems high, 605hp no tune and just a intake and CBE?
Old 05-10-2022, 06:41 PM   #20
s346k
s346k's Avatar
Drives: like an old lady
Track times, ET, and 60-130 will paint a much better picture than a dyno can.
this is blasphemy. real world results? but how would we argue over 10-20 hp if we weren't comparing a million different cars on different dynos? but the dyno said it made an extra 12 hp, its definitely a worthwhile mod, idk why it runs the same. must be the weather.
2016+ camaro: everyone’s first car
s346k is offline   Reply With Quote
Old 05-10-2022, 07:02 PM   #21
clg82
Drives: 2020 Camaro ZL1
My 93 octane tune on a Dynojet in 6th gear made 745 RWHP.
I then had it on a Mustang Dyno at a different shop and it made 688 RWHP in 6th gear with 93 octane.
So yea that is roughly 6-7 percent difference.
Although the shop that had the Mustang Dyno did retune it before they got those numbers. But their tune was more for driveability so they didn't really touch anything to impact the power.
The problem with dyno shops is a lot of them simply plug in numbers here and there and factor in this and that and before you know it they're handing out inflated numbers like candy on Halloween. And they do that because if shop A builds 5 cars and they're all making "900+ RWHP" and shop B is building similar cars but they're making only "820 RWHP" then people are all gonna want shop A doing their work because they're getting inflated numbers. And now there is some new type of dyno that spits out even higher numbers than a Dynojet does. So I wouldn't put too much stock into what the numbers are. Track times, ET, and 60-130 will paint a much better picture than a dyno can.
Serious question, but why those mph specifically?^
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21
clg82 is offline   Reply With Quote
Old 05-10-2022, 07:46 PM   #22
BlaqWhole
I do believe that a dyno has it's purpose. But these days that purpose is limited to seeing what difference a specific mod makes after it is installed. So if I swap a pulley and am now making an extra 25 RWHP then it served it's purpose. But when there are hundreds of dynos and some of them allow for factors to be typed in to get a higher reading or some of them can be altered and some read higher than others and yada yada, then those results all become diluted.
I think a good rule of thumb would be to factor in a +/- range to account for errors and variances and other BS. So if you're making, as an example, 750, then it should be a range instead of a hard set number. So 750 should be more like approx 735-765 given the same type of dyno and similar conditions. And really, it is just splitting hairs when you're comparing a 760 RWHP dyno run to a 740 RWHP dyno run. When factoring in a range, any given day a 740 RWHP car can beat a 760 RWHP car.
It seems to be a good starting and stopping range. I also think at those speeds, once you get to 120-130, you're pretty much not gonna stay in it. And if you're ahead of the person at 120 chances are they won't catch up given you didn't just get a lucky jump. In some cases there have been GTs and GT guys with mods who have been able to keep up with or even get the edge on stock ZL1s to about 120-ish...at which point the ZL1 just barrels past them. But I would think that 60 to 130 is the best range to determine which car is faster. And with Dragy boxes it is becoming the standard test.
Old 05-11-2022, 06:53 AM   #23
cjperformance
cjperformance's Avatar
Drives: 2017 Camaro SS 50th Anniversary
Testing 60-130 you are much less traction limited too, so measurements can be more accurate on higher hp builds w/o factoring tire slip.
2017 50th Anniversary Edition | P1X Stage 2
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
cjperformance is offline   Reply With Quote
