05-04-2022, 05:24 PM | #1 |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
My new build
Finally completed the build I have always wanted and it has exceeded all my expectations.
Started with just stock tune and rotofab intake (A10). Blake Leonard started Top Speed Cincy about 4 years ago after working for WeaponX. WeaponX quit building engines. It is the same shop with a Mustang dyno but, Blake owns the shop now. Here is the build which was my want list. Stg II btr cam w/ 38% fuel lobe, .660" lift Platinum spring kit, Titanium retainers, chrommoly push rods. STOCK heads and vlvs GM Gen V cam bolt WT Camshaft bolt DSX low side kit NW 103 Rotofab big gulp 2" ARH into 3" with cats, stock muffler Weapon X triple ht exchangers MM cc Kong X port IW V3 ZL1 8-ribbalancer w/ Metco ring BTR GEN V/ afm delete kit BTR Gen V VVT lockout ARP head studs, Johnson lifters ARP LT-4 crank bolt TCM tune Incedentals: Z26 brake pads BMR Lockout kit AMP billet thermostat housing with 160 stat Brisk RR 12S Plugs On a Mustang loaded dyno it pulled 720 rwhp, 634 lbs tq, 15 psi boost, 7th gear pull
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, AWE Touring, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
05-04-2022, 05:30 PM | #2 |
Looks good and nice numbers!
05-04-2022, 06:18 PM | #3 |
Thanks
Guys like you have helped me learn about these cars and specifically engine builds.
05-04-2022, 06:18 PM | #4 | |
Awesome build. I really like the look of the Eaton. Whose lid is that? I'm curious why you stayed with stock heads and valves, an aftermarket set of which makes a dramatic difference.
'20 ZL1 1LE A10,
05-04-2022, 06:38 PM | #5 | |
The lid is made by WeaponX and is only cosmetic but, boy does that blower whine come thru especially with a big gulp. Looking at previous builds with ported stock heads or aftermarket was not in my budget at this time. We determined the cost for at least porting the stock heads would not gain that much for the cost. My goal was the cam, everything else was needed to support that with the budget I had. Today's ride showed me this car does not lack anything for street use only.
05-04-2022, 11:20 PM | #6 |
Drives: 2022 ZL1 Join Date: Dec 2021
Nice Build. Looks Badd Azz
05-05-2022, 05:47 AM | #7 |
Drives: 2018 ZLE Join Date: Feb 2018
Nice work, looks great
05-05-2022, 08:10 AM | #8 |
Drives: 2018 Camaro ZL1 1LE Join Date: Feb 2022
Looks great. How does it sounds with the bigger cam and stock muffler?
05-05-2022, 08:31 AM | #9 |
Nice setup!
2016 NFG 1SS A8
05-05-2022, 01:16 PM | #10 | |
Wish I knew how to upload a video file without putting it on YouTube or I would. Has a muscular crackle and it barks pretty loud when you get on it. What I didn't expect was to hear that much more whine from the blower being ported, WeaponX lid and the big gulp. I also didn't expect to have that much gain with the stock heads. I have no plans at this time to change anything.
05-05-2022, 01:28 PM | #11 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
What do u call dramatic? When i did my build a few years ago, most were reporting 25-35rwhp gain for the $2k investment. That is why i opted not to do them at this point. Are they getting more now as new stuff hits the market?
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
05-05-2022, 01:33 PM | #12 |
My builders experience with ported heads said, "maybe 20 rwhp more" for $2k - $2.5k.
05-05-2022, 02:12 PM | #13 |
That's my understanding as well. 20-25whp. Certainly not dramatic by any means. You have to consider the source.
2016 NFG 1SS A8
05-05-2022, 02:36 PM | #14 |
He's gained 145 hp over stock. My point was that there's an additional ~28-30% available in the heads. To me that's dramatic or considerable. I now see that the OP did not believe there would be sufficient hp/$, which is all I was asking.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 05-06-2022 at 03:10 PM. |
