09-24-2021, 08:15 AM | #1 |
Drives: 2014 Camaro 2LT Deep Magenta Join Date: Apr 2015
Bf good rich comp 2 a/s tire pressure
What tire pressure should I have? I had the stock 19 and run 275/40zr20 all 4 tires. Would it still be 36 cold like the stock tires? Have a 14 camaro 2 lt manual. Thank you guys
My previous set of tires only lasted me 2 years… due to the middle getting bald meaning over inflated. |
09-24-2021, 08:38 AM | #2 |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
Tire pressures stated in the door are based off of GVW. This weight is set as a fully loaded vehicle with passengers and cargo. So setting your pressures to 36psi like it says in the door will be over inflating your tires, unless you drive it daily fully loaded with passengers and cargo. Set your pressures to 33 and pay attention to how the tires are wearing when you do scheduled maintenance, such as oil changes and tire rotations. If they are wearing around the shoulders and not evenly in the center, increase the cold pressure. If they are wearing only in the middle, lower your cold pressure. You want them to wear evenly across the tread.
09-28-2021, 01:42 PM | #3 |
376 cubic inches of fun
I have always used the stated tire pressure of 36 psi, and tire wear has been uniform.
It's important to adjust the tire pressure seasonally, however. Tire pressure goes up approximately 1 psi per 10 degrees F, so if you are at 36 psi in the winter, you need to let some air out in the summer! |
09-28-2021, 06:56 PM | #4 |
I run 36 cold front and back on 275/35/20 and 315/35/20 all year round and the tires wear evenly for me. Conti Extreme Contact DWS06 Sport Plus.
10-02-2021, 05:51 PM | #5 |
I have the BFG's too. I run the 36 psi cold all around and they wear normally.
10-03-2021, 08:36 AM | #6 |
Drives: 2010 2SS/RS, VR ext/Blk Int Join Date: Jul 2012
01-16-2022, 02:36 PM | #7 |
Drives: 2010 CAMARO SS Join Date: Apr 2017
How good are those tires grabbing off the line
01-16-2022, 03:18 PM | #8 |
Not very good unless their hot. After I do about 3 pulls they tend to hook ok.
