Roto-Fab
Old 11-28-2018, 09:26 AM   #1
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
P0300
2 weeks ago our 2010 camaro LS3 started running bad all we got was a P0300 and when we started to work on it too find out what was not working, car seemed to be running on only 4 cylinders any one know whats going on?
Tested compression on all 8 and 7 had 160-165 PSI , 1 was 0, we had both fuel and spark to all 8 cylinders.
2SSRS@Gen5diy is offline   Reply With Quote
Old 11-28-2018, 10:16 AM   #2
Hippy
Hotwheels
Hippy's Avatar
Drives: Hotwheels Edition
Send a message via Skype™ to Hippy
Start with checking
For a Bad valve, Rocker broke..
Broken / stuck rings
Blown head gasket..
Sent from my SM-G955U using Tapatalk
Parts for Sale
2013 2SS Hot Wheels Edition 734 of 1524
Hippy is offline   Reply With Quote
Old 11-28-2018, 10:26 AM   #3
camguynj
camguynj's Avatar
How many miles? Any engine mods ...how many miles go ?
Old 11-28-2018, 12:29 PM   #4
2SSRS@Gen5diy
Originally Posted by Hippy View Post
Start with checking
Blown head gasket..
Its non of that, we checked and like i said its only running on only 4 cylinders at the moment.
57K no mods this started a week ago and car has not moved, so may be 1-2 mi ago.
Old 11-28-2018, 01:38 PM   #5
camguynj
camguynj's Avatar
What did you do to check the valves, etc?
Old 11-28-2018, 03:42 PM   #6
2SSRS@Gen5diy
Well we did not pull the heads, but looked at them the valves are fine, but we did find a broken out side spring.
but how will that make it run on only 4 cylinders?.
Old 11-28-2018, 04:17 PM   #7
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Dead cylinders all on same bank?...rat chewed thru harness wire? Wires make contact with exhaust and burn?
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 11-28-2018, 04:37 PM   #8
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
someone had this issue last week and itr ended up being fuelinjection related....ill look for the post
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 11-28-2018, 05:26 PM   #9
RankSS
Drives: 2010 Camaro SS
Are you saying one of the cylinders has zero
compression???
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
Old 11-28-2018, 09:19 PM   #10
xc_SS/RS
Drives: 2010 Camaro SS/RS
Check the coil and injector grounds on that side. My shop removed a spark plug that was stuck in the head and had one bank not fire at all after putting it back together. Turned out a ground wire had gotten cut
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 11-29-2018, 11:19 AM   #11
2SSRS@Gen5diy
No, 2 rears on both banks are not working, and wires are fine.
Thanks but all 8 are tested and work.
compression???
Yes thats what we are saying.
Its both sides, that only the rear 2 per side do not fire.
Old 11-29-2018, 12:01 PM   #12
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
Id start by figuring out why there is zero compression in the one cylinder. Sounds like there is a broken valve spring, so I would fix that, retest compression and then go from there. I'm curious how you know it is only running on 4 cylinders.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 11-30-2018, 01:27 PM   #13
Hippy
Hotwheels
Hippy's Avatar
Here you said 1 cylinder has 0 compression..
Doesn't matter if it has spark or not..In half or all of them. First figure out why there isn't compression.. In 1 cylinder
Have you tested for spark?
All I remember was that you said it seamed like it was only running on 4 cylinders
Parts for Sale
Old 12-05-2018, 01:09 PM   #14
2SSRS@Gen5diy
Yes it had 0 compression in #7 cylinder till we fixed it last night.
we know why cylinder #7 had a broken outer spring.
Yes all 8 had spark, that was tested, all 8 had fuel and the injectors where pulsing when tested.
We ran a infrared heat gun on all 8 cylinders, #1 and 3 and 2 and 4 where over 500+ degrees 5+7+6+8 where running 160 or so.
So after we replace only one set of valve springs on #7 cylinder we tested the compression there all back to 165 LB and car starts and runs fine, its ward to me and my guys that only one cylinder made the rest of the rear cylinders run cooled and no power.
Last it did not trow a code for only one cylinder but the random P0300, any one know why?
