04-04-2016, 10:16 PM | #1 |
Drives: 2010 Transformers 2SS M6 Join Date: Feb 2016
1LE Track Pack Arrived but no springs or strut top mount like picture!
Anyone else order a 1LE track pack with the company showing a picture like the one below however no springs or strut mount were included for the fronts when you received the package?
04-05-2016, 06:10 AM | #2 |
Drives: '16 FiST Join Date: Apr 2012
Im pretty sure those are the rear mounts and you re-use your front mounts and oem springs
04-05-2016, 06:49 AM | #3 |
No, the front does not come like pictured, only the strut.
04-05-2016, 06:54 AM | #4 |
Drives: 2015 Black 2LT RS M6 Join Date: Aug 2015
Not entirely true. If you order the "V6" 1le kit it does come with the front springs. The "v8" kit does not come with the front springs because they are the same as your SS springs
V6 kit# 23123398 V8 kit# 23123397 Read more here http://gmserviceinsights.com/2014/04...os-a-1le-feel/
Overkill tune/E85/80mm•CAI cold air intake w/my custom maf tube•Apex air scoop•JacFab ported intake/Extendolater•Vitesse•EE EX2 catch can•Innovate wideband•ARH HFC's•NPP exhaust•11386 xpipe•Brembos/cross drilled/slotted rotors•SS M/C•Pfadt 1.25 springs•1LE struts/sways/strut tower brace•BMR diff bush, trail arms/bush, adj toe links•My custom Tunnel brace•Hurst short throw shifter•JDP stage 1 clutch res•1LE steering wheel, shift boot•ZL1 rear diffuser/splash guards•GM splitter•Z/28 grille/flowtie/spoiler/wheels•GM performance pedals•"Chevrolet" door sills•10" Kicker sub•BigWorm overlays
04-05-2016, 09:01 AM | #5 | |
Drives: 2015 1LS Red V6 Join Date: Aug 2015
Sponsors:
Overkill Motorsport BCS Auto JacFab Machining APDEG Dream Gear Mobile Audio Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet 5th Gen V6 Performance Facebook Group |
04-05-2016, 09:51 AM | #6 | |
04-05-2016, 12:40 PM | #7 |
Thanks all. I should have probably just ordered all the components separately with my wholesale discount at the dealer. I thought I was getting a better deal because the fronts were coming assembled :-/
04-05-2016, 01:28 PM | #8 |
What's sad is both kits are the same price
04-05-2016, 02:16 PM | #9 |
Ordered mine from Summit Racing. $1179 shipped.
04-05-2016, 02:30 PM | #10 |
It comes with everything you need, you can reuse the springs and such. Only thing you will need extra is the rear lower control arms as you have a 2010.
01-29-2017, 01:34 AM | #11 |
Drives: 2014 SS L99 Join Date: Dec 2014
I have the track pack kit, and plan to upgrade front wheels from the 20x8's to the rear 20x9's with 275's at all 4 corners. I figured this would be a cost effective way to get a square tire setup but I've read on here some that it might have some snap oversteer issues without also upgrading cradle bushings. Is this something I need to be concerned about? I currently have a stock 2014 SS coupe with zl1 rotors and calipers on front and ctsv rotors on back.
01-31-2017, 07:09 AM | #12 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
The springs are the same with 2012+ SS cars, which had an upgraded base suspension. I would check part numbers for earlier cars. The springs are cheap.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
01-31-2017, 02:01 PM | #13 | |
Snap Oversteer
Orange Krush II
01-31-2017, 05:16 PM | #14 |
Drives: cars Join Date: May 2011
If someone tells you a cradle bushing fixes snap oversteer you should suggest they not reproduce and cease taking any and all automotive advice from them. Just FYI.
