TireRack
Old 02-11-2016, 06:02 PM   #1
crit
Drives: 2010 Transformers 2SS M6
Help please, bought a car with a cut engine harness :-(
Posted this in the engine section but this might be a better section for the problem:
I just bought a 2010 SS from auction and when I popped the hood discovered that someone had cut the engine harness next to the fuse box. It wouldn't be a problem normally because I would just splice the wires back together but there are multiple wires of the same color (4 light tan) so I was wondering if someone had a wiring diagram for the 2010-11 6.2L? I'm guessing because the wires are the same colors they are probably shared grounds among multiple sensors so probably not a big deal if one tan wire is swapped with another but I just want to make sure. Please let me know if you can help. Thanks!!
crit is offline   Reply With Quote
