Old 02-11-2016, 03:50 PM   #1
crit
Drives: 2010 Transformers 2SS M6
Help please, bought a car with a cut engine harness :-(
Hi All, a new forum member here. I just bought a 2010 SS from auction and when I popped the hood discovered that someone had cut the engine harness next to the fuse box. It wouldn't be a problem normally because I would just splice the wires back together but there are multiple wires of the same color (4 light tan) so I was wondering if someone had a wiring diagram for the 2010-11 6.2L? I'm guessing because the wires are the same colors they are probably shared grounds among multiple sensors so probably not a big deal if one tan wire is swapped with another but I just want to make sure. Please let me know if you can help. Thanks!!
crit is offline   Reply With Quote
Old 02-12-2016, 12:58 PM   #2
Aaron0731
Drives: 2010 2SS/RS L99
I would try and google that. Man that sucks! Maybe you can get a refund?
Aaron0731 is offline   Reply With Quote
Old 02-13-2016, 02:54 PM   #3
granatl
granatl's Avatar
Drives: 2SS RS ABM A6
A new wiring harness from GM isn't all that expensive and will probably take you less time to change it than repair it. I accidentally burned my on my exhaust and swapped it out in a few hours.
Jack Bilger
granatl is offline   Reply With Quote
Old 02-13-2016, 03:33 PM   #4
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
+1, just buy the harness.
its about 300 dollars shipped.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - Stock
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 02-14-2016, 09:25 AM   #5
crit
Thanks guys for the support and recommendation to swap the harness. Were you able to reach all the sensor clips and replace the engine harness without removing the exhaust and accessories?
Old 02-14-2016, 11:00 AM   #6
Buschman
Buschman's Avatar
Drives: 2018 ZL1 2015 1SS 1LE
I would be more concerned with what else was done to damage the car? If someone was that pissed to cut the harness..... I would be taking it to a trusted mechanic and have the entire car looked over. At the least, I would be draining the gas tank and replacing all fluids.
2018 ZL1
2015 1SS 1LE
Stock...ish
Buschman is offline   Reply With Quote
Old 02-15-2016, 01:02 PM   #7
granatl
granatl's Avatar
From what I remember, no, I didn't have to remove anything. Pay close attention (i.e. take pictures) of the current routing, etc.
The one for the A6 transmission was a bit tricky.
Jack Bilger
Old 02-27-2016, 10:40 PM   #8
TheBonfiggy
Drives: 2013 Camaro 1LE
Anyone who has replaced their harness before know how long it took them from start to finish? Also, how difficult is it to do?
TheBonfiggy is offline   Reply With Quote
