06-16-2020, 01:02 PM | #1 |
Drives: Chevy Camaro ZL-1 Join Date: Feb 2020
How much horsepower equates to quarter mile times
I notice a lot of people discussing adding horsepower and final dyno numbers on their ZL1s. I was wondering how that effects quarter mile times. Yes I know tires, traction, weather, altitude all effects numbers.
According to most reports a stock LSA-Zl1 runs approximately 11.9-12.2 quarter mile times (avg). Depending on 6-speed or Auto. I was wondering how much that time changes with adding 100 HP or 150 HP or 200 HP. for example what does it take to get into the 10s? If anyone has run their stock car and later modded it and re-run I was just wondering if it helped with their time. Thanks Chuck |
06-16-2020, 01:14 PM | #2 |
Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
06-16-2020, 09:06 PM | #3 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
11.9 - 118.6 stock with Michelin AS3 performance all season radial 285/20/35 in the rear/ square setup. JRE 125 package 11.3 - 124.5 same tire setup. |
06-16-2020, 09:23 PM | #4 | |
Drives: 2013 Camaro SS Join Date: Feb 2017
2013 Camaro SS
Kooks Headers Vararam DRX 1le Differential 3.91 Bo White throttle body Magnaflow Competition Exhaust 12.391 112 MPH 10/05/19 |
06-17-2020, 05:48 AM | #5 | |
I think in actuality it's more like half that for most of us as ZME posted. He gained 0.6 for the 125 package. |
06-17-2020, 11:25 AM | #6 |
It's not a linear solution. The faster you go, the more hp it takes to go incrementally faster.
06-18-2020, 11:46 AM | #7 |
thanks guys
06-21-2020, 12:43 PM | #8 |
Drives: 2014 M6 ZL1 Join Date: Jan 2012
Great thread topic. Automatics probably take the driver mod on trap speed out of the equation.
Vehicle weight, density altitude, wind direction, track surface & prep, tire pressure, and vehicle downforce all play a factor. I’m sure I’ve left a few variables out. Went way back to find these initial 1/4 mile runs in 2800 DA at Bradenton. Car was probably making +15-20 hp over stock. Let’s say 600 crank Hp trapping 111-112 MPH https://www.camaro5.com/forums/showthread.php?t=363932 Car trapped 137 in 2000 DA last month at same track with +300 crank HP thru M6.
15' Ashen Gray Metallic Z/28
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH 12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD 06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD. 96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH Last edited by 2NASSTY; 06-22-2020 at 12:19 AM. |
06-24-2020, 08:51 AM | #9 |
Drives: 2012 2SS CAMARO 45th Join Date: Apr 2011
http://www.wallaceracing.com/et-hp-mph.php
This is a fun calculator. Put in your weight and horsepower and it'll give you a rough estimate. Obviously things like trans and tires have a lot more to do with it but it's a good idea of where you can be. .1 for every 10 horsepower might work when you're in the 13s but the faster you go will always require more power to get to the next level. |
06-24-2020, 08:23 PM | #10 |
Drives: 1970 Buick GSX Join Date: Feb 2020
Ran my 2013 ZL1,..made 715 on the dyno,..trapped 125mph in 3000DA so take that for what its worth,. Slightly liberal dyno and crappy weather
07-24-2020, 05:25 PM | #11 |
