09-01-2010, 08:29 AM | #1 |
Drives: Black 2010 Camaro LS Join Date: Jul 2010
Barton Shifter Vibration Disappears w/ windows down
Sounds weird I know but it was repeatable several times this morning.
Installed my Barton shifter about two weeks ago and absolutely love it but it does tend to have some vibration feedback, at upper rpms (4k-5k), that I can hear and feel through the stick. I am 100% sure it is installed correctly and yes the vibration is coming from the shifter as I can feel it and see it also. At least it is translating through the shifter. Morning temps the last few days have been around 70 degrees here so I had the windows down driving to work. I noticed yesterday that I neither heard nor felt any of the vibrations through my shifter when accelerating hard. On the way home when it was close to 100 degrees I had the windows up and yep there was my shifter vibrating when briskly accelerating. So this morning had the windows down again and same thing no vibrations. Put the windows up and accelerated hard and there it was again. Immediately put the windows down and accelerated hard, no audible vibration or vibrations felt through the shifter. Now I would call myself crazy and this a fluke if I couldn't repeat it which I have been able to so far. I am going to test again this afternoon. Curious to see if any Barton or Hurst owners having vibrations can test this as well. I am wondering if by opening the windows the lack of pressure in the cabin is dissapating some overall vibrations that just happen to be translating through the shifter. If the tranny was the source of the vibrations, I don't see how the windows would make a difference. Any ideas??? |
09-01-2010, 08:53 AM | #2 |
I am guessing you have the M6. From what I have heard some of the aftermarket shifters have had vibration issues, might want to check with Barton, and see if they have a quick fix solution for it.
Formerly owner of:
2012 2SS/RS Build Thread - Totaled by red light runner 2010 LT/RS Build Thread - Traded in for 2012 2SS 2007 Acura TSX 1992 Oldsmobile Achieva V6 1992 Mercury Sable |
09-01-2010, 09:08 AM | #3 | |
Its not that bad but the fact that it goes away with the windows down is puzzling. |
09-01-2010, 09:47 AM | #4 |
Drives: 11 2SS/RS E-Force Supercharged Join Date: Apr 2010
I wrapped teflon tape on the shifter shaft and a nylon washer on the shift ball jam nut. Removed all my rattles. You will probably always feel it but hearing it can be fixed.
09-01-2010, 10:10 AM | #5 | |
Mine vibrates even without the shifter ball installed. Not saying that the teflon or washer wouldn't help though. |
09-01-2010, 11:05 AM | #6 |
Catch me if you can
Check the dust boot under the shift. If is not attached correctly it can give the effect of a shaking shifter.
09-01-2010, 11:19 AM | #7 | |
Baffled by the windows being up or down having an affect on it. |
09-01-2010, 02:27 PM | #8 |
Drives: 2011 RJT 2LT/RS Convertible Join Date: Nov 2009
Are the centering springs installed correctly?
1st IPF Supercharged 2011 2LT/RS RJT Convertible
09-01-2010, 02:53 PM | #9 |
So-Cal Race team!!
Drives: Tahoe LTZ,2010 2SS/M6 Camaro Join Date: Apr 2009
Really I'm going to try this.......mine is not bad at all but just a little.Doesnt brother me but some others hear it...
WE RACE DEEP!!
BBK Intake, Flowmaster AT cat back Barton shifter,Painted stripes,,Heritage grill,LED DRLs, Smokin Tires!! |
09-01-2010, 02:55 PM | #10 |
So-Cal Race team!!
Windows down I'm sure you cant hear it with the exhaust and wind make more noise than the shifter
WE RACE DEEP!!
09-01-2010, 05:11 PM | #11 |
09-02-2010, 09:32 AM | #12 |
I've done the dynomat and teflon tape and still have vibration at higher RPMs - not bad, but its there.
Black 2SS ordered 1/4/2010, received 2/19/2010
09-02-2010, 02:16 PM | #13 |
Drives: SuperCharged 2SS/RS IOM MN6 Join Date: May 2009
shifter noise and window being up/down...I can't imagine a connection. Like someone said, road and wind noise will drown out faint rattles/vibrations in the cabin. If the rattle noise comes on with window up, and goes away with window down...maybe the noise is not from the shifter, maybe it is from the window or door panel and your left ear is no workie workie very well.
09-02-2010, 02:49 PM | #14 |
The windows down might change the resonant frequency of the body enough for the particular problem not to vibrate. The frequencies the body exhibits will change based on temperature, windows up, windows down, loading (people in car, objects in car), etc.
Similar Threads | ||||
TAG's 2010 THRSS #2 | TAG UR IT | Member Car Journals | 3129 | 08-14-2014 09:29 AM |
Barton Industries Shifter handle | valed4313 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 14 | 12-11-2010 11:01 AM |
Barton Shifter | motor1 | Transmission / Driveline | 1 | 07-31-2010 09:13 PM |
Barton Industries shifter | Chief Bob | Vendor and Seller review / feedback / experiences | 1 | 07-16-2010 07:44 PM |
The BEST upgrade for your new Camaro - Camaro Six Shooter shifter | MTI Racing | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 19 | 07-23-2009 02:52 PM |
