Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Exterior Parts & Accessories
Old 07-26-2018, 09:36 AM   #1
sjmautoprod
sjmautoprod's Avatar
Drives: '16 2SS
LED Spot Lights
Before NightOwl went away, both of us were working on small, LED spot lights. The NightOwl offering was very nice, but I felt that they were a bit pricey ($275 for a set of two, if I recall correctly), so I continued looking at them. The compromise we made was to reduce the power to the point of not needing a metal housing, which was most of the cost: a custom-machined, low-volume, aluminum part. They are still nice and bright, though!
The housings we are using are 3D-printed in black, ABS plastic. They are o-ring sealed, but the LED-driver box is open. A sealed box will be an available option for around $20. There is a short cable to connect to your controller and then 10' of cable to the spot itself.
There are several mounting options: 1/8" clip (shown above) which works well on hood pads and some other cars' vent ducts ; a hood-pad fastener (sized for the 5th gen; different sizes on-request); and a generic through-hole bracket.
These will work with any common-positive LED controller.
We're looking for a few people to help test these out with us. The early-adopter price for one spot is $59. The final price is estimated to be around $85 each, unless something major pops up.
Let us know if you are interested!
sjmautoprod is offline   Reply With Quote
Old 07-31-2018, 12:51 AM   #2
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
What is a "common-positive" LED controller? Would this work with the nightowl system or do we need another system?
Old 07-31-2018, 07:21 AM   #3
sjmautoprod
Drives: '16 2SS
Yes, NightOwl modules are common-positive controllers (wiring is R, G, B, and +).
Old 08-01-2018, 09:24 PM   #4
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
Nightowl controllers are not RGBW however, correct?
Old 08-02-2018, 07:57 AM   #5
sjmautoprod
Drives: '16 2SS
The SL v3 modules are RGBW.
