05-03-2015, 05:29 PM | #1 |
Drives: 2013 Camaro 2SS RS 1LE Join Date: Feb 2015
AC Recharge
I feel kind of stupid asking this as I've done this several times before on other cars, but I can't seem to figure out where the low pressure line for the AC to do a recharge on my 2013 Camaro SS 1LE.
I see the both the caps for the low and high but I don't know which is which. I usually thought that the low pressure one was the one with the thinner tube and the high pressure had the thicker tube, but when I tried the connect the recharge kit connector into what I thought was the low pressure line (the one on the front near the washer fluid and intake), it did not fit . So now I'm confused Can someone please lead me in the right direction? Maybe post a picture of the right one if possible? Thanks!! |
05-03-2015, 08:36 PM | #2 |
Bring the funk!
Tail of the Dragon - 318 curves in 11 miles!
05-03-2015, 08:38 PM | #3 | |
That's for the V6 version. Is it the same for the V8 Camaros? |
05-03-2015, 11:43 PM | #4 |
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
It will only fit one port. If it doesn't fit, it's the wrong one. If it does fit, it's the right one. Have you had the system unhooked, or do you have a leak?
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
