05-22-2017, 04:47 PM | #1 |
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
Launch Control is fun + 0-60
yep...it's fun, real fun.
The initial rev gets the attention of surrounding vehicles and then, off you go.... Sadly the best I have gotten is 5.7 0-60 (in about a dozen attempts), but this is at 6200 feet (probably a DA correction of 1.25), but that's with lifting to shift and not at all pushing it to redline in first, probably 5K to 5.5K-ish (i'll have to actually look at the video to be sure). I should try no lift and a 6000RPM shift. What should I be aiming for at 6200' altitude? What about clutch release...dump it or what? I am a bit timid with the clutch, although fast enough that the wheels are spinning just a tad off the line, I mean, like half a second to a second or so (this is in RACE mode).
2017 SS 1LE | HBM | Vortech V3-Si supercharger (620RWHP and 575ft lbs) | PDR | Black Bowties | Illuminated Front Black Bowtie | Illuminated Door Sills | Smoked Tails | vented seats mod
05-22-2017, 06:07 PM | #2 |
Markoon13
Drives: Camaro 2SS Join Date: Oct 2016
My best results have been with releasing the clutch slower about half way and then dump it the rest of the way. If I just dump the clutch, the tires spin a bit too much.
05-22-2017, 08:13 PM | #3 |
Drives: Hard Join Date: Feb 2016
Aside from the fact that it sounds like the world's loudest fart—no lift shift is awesome... like going from ludicrous speed to plaid!
'16 2SS, 6MT, MRC, NPP, sways, square 285's—and an ear-to-ear grin!
05-23-2017, 06:18 AM | #4 | |
Drives: 16 2SS Join Date: Feb 2017
2016 2SS, A8, Whipple 3.25 pulley, Mishimoto catch can, C7 Carbon fiber splitter and skirts, GM black brake and tail lights. PLX wideband O2/HP tuners. Apex VS-5RS in 19x11 and 19x12.
05-23-2017, 02:59 PM | #5 |
Hmmm, well ok then I don't feel to bad with 5.7 on a M6 at 6200 feet, I think I should be able to get it down another half second or so.
05-23-2017, 04:46 PM | #6 |
Drives: Mitsubishi Evolution X Join Date: Nov 2016
Isn't it more fun to figure it out by using it?
05-23-2017, 05:22 PM | #7 |
05-23-2017, 10:33 PM | #8 |
Easily. You should still be able to get in the 4's at altitude. You will need a warm day though.
05-23-2017, 11:16 PM | #9 |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
Lmao. My thoughts too.
But back to topic, My one try with using the launch control was not good lol. When I launched it spun my tires up to 4500 before it cut power. I probably should experiment with it some more tho and see if I can figure it out better.
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
05-23-2017, 11:52 PM | #10 |
My first try I didn't hold brakes hard enough just smoked the tires.
05-24-2017, 01:49 AM | #11 |
Drives: 2022 Satin Steel ZL1 M6 Join Date: Sep 2015
Don't feel too bad at all. I have had my M6 SS for 20 months/12,000 miles and I can't get under 4.9 to 60MPH in Denver no matter how perfect a launch, and I can launch it perfectly, no bogdown and very minimal wheel-spin. And where in the Denver area are you, at 6200feet, so I can be on the look out for a 1LE?
05-24-2017, 08:29 AM | #12 |
Drives: 2017 Camaro SS FIFTY Join Date: Dec 2016
This was after about a dozen attempts with my A8 vert. I have tried launch is Sport and Track. Top up and top down. Can't find the sweet spot. Also get so excited to execute there have been at least a half dozen times I forgot to start the timer!!!
05-24-2017, 09:28 AM | #13 | |
I'm in Parker, but work downtown denver, My launches are in Parker though; a lot of open roads here. I tried a no lift shift yesterday and I don't think this car has that feature (i know been debated to death), but when I tried it, RPM jumped and car lurched pretty bad, so I don't think I'll try that again.
05-24-2017, 09:31 AM | #14 |
Yeah, that's too much spin I think . I have let the clutch out fairly slow (IMO?) enough to only spin maybe a single rotation or so, not much at all. I would think this would be a good launch, but the numbers aren't there, so....
