02-15-2017, 11:52 AM | #1 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
Adding a heated steering wheel
Hi everyone, I'm currently researching what it would take to add a heated steering wheel to one of our Camaros that doesn't come with a heated wheel from the factory. Parts needed to switch that I've found so far are:
The heated wheels already have the controller for heat mounted inside in them, only trick is getting 12V power and ground to the controller. The airbag harness coil for cars with heated wheel have this, but I'm not sure if it can be bought separately or if it comes through dealers as part of the turn signal/wiper switch assembly. From there, it looks like the rest of the wiring harness comes on all Camaro variants, but I don't know if any fuses or anything need to be added. I'm planning to look for said connector on the wiring harness as well as test with a voltmeter to see if it's live or not. Will update later with any findings. Has anyone else done some digging or successfully installed a heated steering wheel? Didn't find anything with a search.
2017 SS 1LE.
02-26-2017, 08:09 AM | #2 | |
Drives: 2016 1ss red hot Join Date: Aug 2016
02-26-2017, 11:07 AM | #3 |
SABIO
Drives: 2016 CAMARO 1SS Join Date: Jul 2015
Talk to a dealer? They have drawings/diagrams, etc
02-26-2017, 09:17 PM | #4 |
i work at a dealership so I will find out tomorrow guys!
02-27-2017, 09:25 AM | #5 |
Sorry, haven't had a chance to dig into mine yet to physically check anything, but have been able to do a little more digging on the virtual side.
To add to my first post, looks like this connector lives inside the plastic steering column shroud. If you pull the shroud off, it should be a 2-pin connector attached to the RH side of the steering column underneath gauge cluster. As for the SRS coil, looks like it's PN 84205927 but I haven't seen it for sale individually anywhere online. Izuniga, are you able to see if this part can be ordered through your dealer's service department? Wasn't sure if you could get the coil on its own or if you had to order the entire turn signal/wiper switch assembly. EDIT: Did some more searching, looks like PN 23465301 would be the right coil. No need to replace the whole switch assembly. Probably should confirm fitment with a dealer or other GM vendor before buying, though, just to make sure I'm correct
2017 SS 1LE.
02-28-2017, 07:48 PM | #6 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
You may want to check, I think the BCM is involved in this as well.
03-01-2017, 07:34 AM | #7 |
Drives: 2016 1LT V6 6MT Convertible Join Date: Aug 2016
Oh man, I've been wanting to do this since I bought my 2016 V6 Vert. It would be super nice to have heated steering wheel on cool nights. Now, does anyone know how to add heated side mirrors. Visibility in the rain is my only gripe about the car.
Adding Heated Steering and Side mirrors would be perfect for me, but it would have been too much to buy new ($5000 more than base, ouch!) |
03-01-2017, 08:17 AM | #8 | |
First thing I plan to do is check the connector in the steering column to see if it gets power when the car is running, hoping to get at that this weekend.
2017 SS 1LE.
03-02-2017, 04:47 AM | #9 |
Drives: 2017 1ss Join Date: Jan 2017
tried to do a bit of digging into the info on this as well . from what I can gather the heated plug is the one that goes through the square port in the wheel directly under the steering wheel retaing bolt . blue and a gray or white wire that plugs into the bottom right inside the wheel ( close in prox to where the volume buttons are ). it seems based on some bad illustrations for the part # you listed ( 23491040 ) that that clock spring not only carries the power to the heat function but it is also the same one for the air bag plugs . i will do atad more digging but i do wish I could find a good photo of that part rather then a general outline image .
03-07-2017, 04:55 PM | #10 |
I hit a dead end. Quick version of how to take the top of the shroud off:
So, my question is, anyone out there with a heated wheel willing to pop their column shroud open and take a look? See if there is a connector here? If there is a connector here, could you check with a multi-meter to see if you are just getting constant 12V when keyed on and/or with engine running? If it is just getting 12V, it seems like it's just a matter of tapping into another constant 12V source. I know from experience that these wheels can draw a lot of current on startup, so I would suggest at least a 20A fuse if anyone pulls the trigger and wires one up themselves. I will also try to verify if I can get my hands on one of these with the heated steering wheel option, but I don't personally know anyone that has one.
2017 SS 1LE.
03-13-2017, 04:31 PM | #11 |
Drives: New : 2017 SS 1LE Old: 2012 TTRS M6 Join Date: Oct 2015
Any progress? I posted a request in the electronic technical forum liking to your thread... what about wiring a secondary 12v wire to power the wheel heater? I'm having a car stereo guy look into it
. https://www.wheelwell.com/profile/56...ed9c3a/garage/ . . Project 1LE Wraith: http://www.camaro6.com/forums/showthread.php?t=474068 |
03-24-2017, 08:07 PM | #12 |
Thanks for the request! No updates yet. I assume that a secondary 12V hookup would work based on previous experience, but I'm still wanting to check out a car with heated wheel from the factory to confirm. Don't want anyone to go through all the trouble of trying to wire one in on my word if I'm wrong haha.
2017 SS 1LE.
04-23-2017, 07:46 PM | #13 |
04-24-2017, 11:38 AM | #14 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
There is more going on then you know.
