11-08-2023, 11:16 AM | #1 |
Can I get a consesnus on liftpads/jackpads/pucks?
Hey guys,
Making my first purchase for the car today, and am trying to figure out the best way to get this car off the ground. Looking for a clear cut, workable answer here. I'm looking at these https://www.harborfreight.com/automo...ads-58789.html for the jack stands. I currently have these: https://www.harborfreight.com/automo...ray-70594.html could these work? Now I am wondering how to get the car up in the air and actually "jack it". I have a low clearance floor jack from harbor freight that looks like this one: https://www.harborfreight.com/automo...ack-64781.html Not exactly, but close enough. I've got the side skirts/GFX on the side, and noticed this has the "Cupped" jack. Moving forward I was looking at the ever popular ZL1 Addons items, specifically this: https://zl1addons.com/collections/ca...-3-jack-magpad Which is referred to as a "Jack Magpad" and this https://zl1addons.com/collections/ca...alth-lift-pads Referred to as "Stealth Lift Pads" the regular lift pads are out of stock everywhere. At this time I cannot afford a quickjack Now if I want to lift the car, if im understanding correctly, you do one side at a time, a jack stand at the front and rear. If I were to buy one set of 4, which one would I need? Do I get the jack pads that look like they would fit in the cup of the jack? Or the lift pads? Would I get both? Is there a working cheap solution for a jack pad, and the use the "lift pads" to place the jacks under? Will the flat jack stands be secure enough to hold the smaller area of the stealth pad? Will the GFX be in the way? I apologize for the long winded question here, but I want to be extremely careful with this as I have never lifted a car one side at a time before. In short, what should I buy, and what is the proper procedure? Do I need the Jack and Lift pads? Thanks for any help, just looking for a clear cut answer as to where to place my money.
2024 2SS Camaro, Riverside Blue Metallic, NPP, F55, CF5, 5ZZ, VTU, S0O, 5KP, JF5, 2nd Gen GFX
11-08-2023, 11:39 AM | #2 |
11-08-2023, 12:03 PM | #3 | |
I have the same HF jack you are considering. I also have one set of the ZL1 gizmo plus plastic puck. Sounds like you lift the car from the center pinch weld area on both sides. Place jackstands under both front pinch welds. Raise rear using steel cross beam. Then support with jackstands under rear pinch welds. personally, I don't like the idea of the car just "floating" on jackstands. I also stack a pile of 2x10's under each tire as a backup. |
11-08-2023, 12:19 PM | #4 |
Drives: 23 2SS 1LE Join Date: Feb 2019
Just a heads up, if you plan on ever getting a Quick Jack in the future (or similar solution) just wait until you can get the full size lift pads. (There are off brand options that work just as well too) The stealth versions don't give enough clearance.
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 Black on black 2019 3LT RS Camaro. 1100: 3/7/19 | 4200: 4/15/19 3100: 3/15/19 | 4800: 4/23/19 3400: 3/22/19 | 5000: 4/25/19 Built: 4/8/19 | Home: 4/26/19 |
11-08-2023, 06:02 PM | #5 |
Can I use the lift pads with jack stands? And if so do I need the flat top stands or will my arches ones work?
11-08-2023, 09:10 PM | #6 | |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
I got the standard ZL1 Addons lift pads, one of their mag pads (without puck, I got a hockey puck off of Amazon), and a set of the excellent flat-top Esco jack stands. I installed the lift pads in the open spaces nearest to the wheels. When I want to jack up the car, I put the mag pad in the second opening behind the front wheel. This will jack up both side wheels at the same time. This allows me to place the flat-top jack stands under under one or both of the lift pads, depending on what I am doing. |
11-08-2023, 09:21 PM | #7 |
L8ap3x
Lethal does a very nice job in answering the questions that you have in this video.
https://youtu.be/NX_Qf9wSwos?si=jMqU9IW7caMqhmrh
"Manuals win hearts. Automatics win races."
2018 2SS 1LE HBM 6M |
11-08-2023, 09:31 PM | #8 | |
2020 Shadow Gray 2SS
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
11-09-2023, 12:01 AM | #9 |
L8ap3x
Couldn't agree more with this poster. I have the QJ 5000 TL and 99% of lifting is done with it.
11-09-2023, 06:32 AM | #10 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
Yes to everything, because having extra is good..lol.
I have installed the ZL1 Lift pads, but I also have a jack Magpad from Amazon (definitely want it magnetized to stick to the car while you move your jack around) and a puck for multipurpose times, like for jack or jackstand. |
11-09-2023, 07:16 AM | #11 |
Snackbar Tuning
I use the Quick Jack 5000 Xtended version at home. No jack pads or anything. Just the tall rubber blocks that come with the quick jack. They fit in the spots needed to lift the car and its very secure. Trying to use jack pads with the quick jack is useless and just makes it more of a PITA and its a lot less "planted" on the quick jack.
So my advice is if you can for out the $$$, skip all of that mess and get the Extended (I think its XLT) version of the Quick Jack 5000 series. If you still want jack pads, I have a set of 4 of the magnetic ones that I bought thinking I would need them with the QJ. Nope, turns out they are a pile of wasted money. I'll prob pop them up for sale soon if I stop forgetting about them. |
11-09-2023, 09:31 AM | #12 | |
11-09-2023, 11:01 AM | #13 |
Who Needs to KNOW?
I use slotted rubber blocks - like heavy duty hockey pucks.
Started off with one for floor jack, since upgraded to set of four when using the lift.
ing for grip.
11-09-2023, 11:03 AM | #14 |
I made some pinch weld adaptors to fit over the rubber blocks that come with the quickjack. It gave me more confidence when lifting the car.
