Vararam
Old 01-06-2019, 10:43 AM   #1
The camaro show
The camaro show's Avatar
Drives: 2015 camaro 2lt
overkill tune question
so my shop went to tune my car today and he said theres no tune on the autocal just stuff that says e37 e38 and that I need to send in a file for my tune? I thought my tune was preloaded on the tuner and that's why I have overkill my mods and that my car was a auto?
Cosmetic mods: SS hood with painted vent, SS bumper, acs 1le front lip black, big worm gfx tinted all lights, solar wing v2, Camaro seat belt pads and oracle color shift halos and fog light halos and rear colorshift bow tie, carbon creations carbon fiber stingray z spoiler
Wheels: lexani r-3 bg finish 19x8.5
Performance: cold air inductions intake, mrt v1, jacfab ported intake manifold, intake manifold spacer, overkill tuned on E85.
The camaro show is offline   Reply With Quote
Old 01-06-2019, 11:18 AM   #2
rozarioorlan
rozarioorlan's Avatar
Drives: 2013 Camaro 2LS
Pretty much all tunes require a “pre reading” before your actual real tune is sent. Essentially what you’re doing is letting Will know how your car is running now so he knows what to adjust and how much to adjust. Otherwise he would’ve just blindly sent a tune without knowing how your specific car is running. You would have to connect the handheld tune and set it to record and drive for about 10 minutes so he can see how it is currently performing. This is something “true, real” tunes require and is not just something Overkill does. Something that comes preloaded is a canned tune.
You will need to take your handheld back and record your data and email it to Will. From there he will send you a transmission and engine tune and you will upload both and see how you like it. If it’s feels good than thats it, you’re done, but if you want something else changed or it’s not feeling as you thought you can email him and he will revise it and send you another until you love one. I think at this point you should just take your car back from the shop since everything is really done on your end now. It’s also good learning experience if you need to change your tune or use the handheld. It’s a little intimidating at first, but it’s nothitn crazy and if you know how to use a computer, use files and email it’s something you can do. There’s also videos up on youtube on how to do it.
2013 2LS - K&N CAI, Overkill Ported 80mm Throttle Body, Overkill E85 Kit and Overkill Tune, Jacfab Ported Intake Manifold and Spacer, Stealth 3.0 TC, ARH Catted Downpipes, Magnaflow Resonated X-Pipe, Resonator Delete, Jones Full Boar Racing Mufflers, BMR 1.2" Lowering Springs, Elite Engineering Catch Can and Clean Side Seperator
rozarioorlan is offline   Reply With Quote
Old 01-06-2019, 12:38 PM   #3
The camaro show
I just got my car back today, thank you that helped a lot.
Old 01-07-2019, 08:13 PM   #4
The camaro show
I now have this issue trying to download efilive. Is it not supported on Mac?
Old 01-07-2019, 09:06 PM   #5
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
I’m not sure in this situation, but from my experience most engineering type software or software like this is Windows based. Apple is great for graphic design work, but terrible for programming or analytical software. Again, not sure if this is quite the case here, but you might reach out to the people whose software it is and see what they have to say.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 01-07-2019, 11:00 PM   #6
yzark99
I run 2 catch cans...
yzark99's Avatar
Drives: 2012 1LT SIM Auto
^Don't waste any time on that. You need a windoze computer to get the app loaded and working properly. I suggest Parallels to allow a VM (virtual machine) on your Mac, and then you can load an old copy of Windoze 7 into the VM. I have this on my work Mac, and run the app and autocal through it - no problems from Will with the tunes (other than the obvious ones - did you get my email? It's been 6 weeks now. What's going on Will? Answer your f'ng emails!)
https://www.parallels.com/landingpag...SAAEgK9BPD_BwE
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more:
yzark99 is offline   Reply With Quote
Old 01-07-2019, 11:57 PM   #7
The camaro show
so I have to pay $80 for it?
Old 01-08-2019, 06:54 AM   #8
Junior
Junior's Avatar
Drives: 2014 2SS/RS A6 AGM
Send a message via Skype™ to Junior
...or borrow a friend's Windows laptop.
Junior is offline   Reply With Quote
Old 01-09-2019, 02:44 AM   #9
Roader
Drives: Camaro
All the issues you’ve had you should of just let the ship do all the work
Roader is offline   Reply With Quote
Old 01-09-2019, 07:19 AM   #10
Starfall
1bad6
Starfall's Avatar
Drives: 2010 camaro
.exe’s such as the one you downloaded are meant to be ran on windows, HOWEVER. Mac has something called “wine” that you can install, and it allows you to run most exe’s without having a windows pc
Mods: trifecta tune on 93 pump gas, mrt v1 Axle-Back, drilled/slotted rotors, 4" quad tips, Res delete, big worm gfx black out kit all around, interior footwell lights.
Starfall is offline   Reply With Quote
