01-27-2019, 04:06 PM | #1 |
Drives: 2011 Camaro SS Join Date: Apr 2014
Rear end questions
I own a 2011 Camaro Ss and recently threw a rod so i dropped in a new zl1 crate engine and threw in pulleys long tube headers and cold air intake and a couple other goodies. Being that the hp definitely increased substantially i need help on what route to go in beefing up the rear because I’m not sure an Ss rear can handle the new power. Any ideas would be greatly appreciated.
01-27-2019, 04:49 PM | #2 |
Get the ZL1 rear end and axles, etc
01-27-2019, 05:06 PM | #3 |
Drives: 2018 ZL1 2015 1SS 1LE Join Date: May 2013
Check out the G-Force 9” kit.
2018 ZL1 2015 1SS 1LE Stock...ish |
01-27-2019, 05:39 PM | #4 |
Drives: 2011 2SS/RS LS3 Join Date: Apr 2017
Upgrade to 3.91 gears and get the most out of that new hp.
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
01-27-2019, 06:34 PM | #5 |
Fast Cars and Old Guitars
Based on my ‘extensive’ reading here, (ha) ZL1 half shafts will be a must. But be prepared, you’ll pretty much be building a ZL1 around that crate!
01-27-2019, 07:18 PM | #6 |
That's basically what I did. But I swapped out the parts before they broke. My garage is full of stock SS parts including the LS3 with 651 miles on it.
01-27-2019, 08:09 PM | #7 |
You must be hangin’ onto them to possibly use. I’m sure there’s some wrenches here who’d buy that stock stuff. But yeah, many pages of threads here. Sometimes, if you can afford it, it’s better to just buy it. But I know people like to build it too. I applaud those who do. Beyond my skill and patience!
01-27-2019, 08:34 PM | #8 |
Drives: 2011 Camaro 2SS Join Date: Dec 2018
You can buy a new ZL1 driveline for $4300 delivered to your door. I just did the same for my 2011 SS. It was an easy swap and beefy as all hell
ECS Big Blower Cam, ECS Novi 2200HD, Meth, FORE dual fuel pump, 850 injectors, BT .660 dual Springs, Katech C5 Timing Chain, High Vol Oil Pump, Kooks headers and Cat Back, MGW Shifter, Monster LT-1 Triple Disk, ZL1 Drive Train 3.73, BMR Rear Trailing Arms, BMR Differential Bushings, BMR Cradle Bushings, NOWEEDS diverters, Doug Ring Tune 893 HP / 718 TQ
01-27-2019, 08:48 PM | #9 |
Drives: 2010 2ss 6 speed Join Date: Apr 2011
eaton tru-trac
01-27-2019, 10:17 PM | #10 |
Drives: 6th Gen NicKey Camaro & others. Join Date: Nov 2015
It mainly depends on a couple of items, how hard are you going to push the LSA, HP/TQ, as well as how you will use the car, Race/Slicks or Street/All seasons.
ZL1 axles only work with ZL1 differential. |
01-28-2019, 07:50 AM | #11 | |
I took out the stock stuff as to not break it so I can put it back in some day. I built it the way I wanted it for now. So you can kiss my ass with your buy it vs build comment. |
01-28-2019, 10:24 AM | #12 |
Drives: Race Car Join Date: Sep 2009
Get some Cradle Bushings
rear end upgrade |
