05-03-2021, 08:32 AM | #1 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
HP Guesses?
So a year ago last week, my car (mods in sig) put down 683whp and 554wtq on straight 93. I am scheduled to hit the same dyno again tomorrow with the following mods...
3" exhaust w/ x-pipe to NPP (in sig but done after last tune) 3.75" Pulley (down from 4.00", should be 2 more psi boost) DSX triple fuel pumps w/ return E85 Flex tune Take a guess and I'll post results tomorrow.
05-03-2021, 08:48 AM | #2 |
Drives: 2012 Camaro SS Join Date: Jun 2019
I'm going to guess... 753.
Also, can you post up what your actual boost is from the dyno graph? I dropped to a 3.875" pulley on my Whipple last year when I did my headers, and I'm thinking about changing to a full 3" exhaust and dropping to the 3.75" pulley this year. Just want to see the actual boost is when you go to the 3.75" pulley. TIA.
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
05-03-2021, 09:01 AM | #3 | |
05-03-2021, 09:10 AM | #4 |
Drives: 2000 Camaro SS, 1966 Mustang Join Date: Jan 2021
I'll guess 789WHP/649WTQ
LS3 Block (427CI) Forged Manley 4.1" crank T-Rod modded LS3 intake (by me) Ported 821 heads (by me) TSP cam 243/255 .621/.619 111 LSA HP tuners pro (by me) https://www.smokingasphalt.com/ https://www.youtube.com/channel/UCR-...cEEQ4y_YaXMD6Q |
05-03-2021, 09:58 AM | #5 |
826hp/702tq if you can keep it fueled
05-03-2021, 10:44 AM | #6 |
I have way more than enough pump now, injectors would be the limiting factor at this point. I still have some room to dial up the fuel pressure another 10 psi if needed.
05-03-2021, 03:04 PM | #7 |
Boosted Moderator
732/590 WAG...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
05-03-2021, 08:20 PM | #8 |
760/625
2011 Camaro SS---SOLD
05-04-2021, 09:14 AM | #9 |
Drives: 2010 Camaro SS Join Date: May 2018
750/630 is my guess
05-04-2021, 10:17 AM | #10 |
So what exhaust was on it when dyno'd last?
05-04-2021, 03:07 PM | #11 |
Just got back home. We were fighting some issues with heat soak and the belt was slipping so it only put down 730/630.
However, looking at it versus one of last year's runs, it should be nudging 800 once I sort out a smaller belt. Sent from my Pixel 5 using Tapatalk
05-04-2021, 03:08 PM | #12 |
Headers, test pipes, and then stock.
05-04-2021, 03:10 PM | #13 |
Drives: T Join Date: Mar 2015
pulley down full exhaust and E85 on a LSA block, if i didnt crack 800 i'd be kinda disappointed lol
05-04-2021, 03:15 PM | #14 | |
