TireRack
Old 11-30-2015, 08:28 AM   #1
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Wheel hop
I've been doing a bunch of reading on wheel hop and how to reduce it but I have a question...does it make sense that the car hops worse on wet or damp pavement?
Weather has been marginal since I bought the car but I'm surprised at how much worse it seems to hop just accelerating (no launch) on damp/wet streets vs dry, plus it doesn't seem to matter if the traction control is on or off. Last time I had car hop bad, it destroyed the transmission in my WRX...
Thanks,
Larry
larry_g is offline   Reply With Quote
Old 11-30-2015, 09:08 AM   #2
Billy10mm
Billy10mm's Avatar
Drives: 2014 Camaro 2SS 1LE NPP
Do NOT leave the traction control on when spinning the wheels. The rear brakes will pulsate to get the spinning under control which will shock the driveline pretty fiercely.
My thoughts on some things:
  • Driving Nannies: If I'm that far out of shape on the street, something has gone terribly wrong and by all means Mr. Computer man, come and get me.
  • G2s: Rock throwing is like like a tramp stamp; although problematic, it's a sign of good things to come.
Billy10mm is offline   Reply With Quote
Old 11-30-2015, 09:35 AM   #3
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
A lot of stick shift sporty cars get wheel hop, might want to look into swapping in some aftermarket suspension parts out back.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 11-30-2015, 09:40 AM   #4
larry_g
larry_g's Avatar
Is the competition mode good enough or do I need the full defeat? I'm fine with controlling wheel spin with my right foot.
Old 11-30-2015, 09:43 AM   #5
Ajdin@A2BMotorsport
Drives: 2013 Camaro 1SS/1LE
The following parts have been proven to reduce wheel hop, we never got to testing them on our 2015 1LE but they will be for 2016.
BMR Trailing Arms (TCA026), BMR Poly Subframe Bushings and BMR Poly Diff Carrier Bushings.
Ajdin@A2BMotorsport is offline   Reply With Quote
Old 11-30-2015, 10:03 AM   #6
Bo White
Bo White's Avatar
I have BMR toe rods, trailing arms and cradle bushings.
From 440rwhp to 680rwhp zero wheel hop on my LS3.
Old 11-30-2015, 02:50 PM   #7
PapaKlutch
PapaKlutch's Avatar
Drives: 2015 Camaro SS/1LE
Straight outta the owners manual:
Competitive Driving Mode (SS
and ZL1 Convertible Only):
Competitive Driving Mode allows full
engine power while the StabiliTrak
system helps maintain directional
control of the vehicle by selective
brake application. In this mode, TCS
is off
and Launch Control is
available.
2015 2SS/1LE/RECARO/NPP/RS/NAV
PapaKlutch is offline   Reply With Quote
Old 11-30-2015, 03:00 PM   #8
bct10985
Busted my transmission output shaft because of wheel hop at the track and i have toe rods, trailing arms, cradle bushings and ZL1 driveline.
Old 12-01-2015, 09:51 AM   #9
Rdunn
Really, Really Fast
Rdunn's Avatar
Drives: 2010 Camaro SS
order this stuff. it will take care of any wheel hop
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
Old 12-02-2015, 12:26 PM   #10
HeavyChevySSRS
HeavyChevySSRS's Avatar
Drives: 2010 SSRS
I had the same issue. Serious wheel hop broke a u joint in the driveshaft now I have a nasty rattle/vibration noise under acceleration. stock suspension and pzeros. Tires and TA along with the bushings for Christmas!
As I lay rubber down the street I pray for traction k can keep, but if I spin and begin to slide please dear god, protect my ride[/I]
10' ls3 2SS/RS, gfx pkg, stainless headers, 3" stainless exhaust, rotofab cai, custom stage 3 cam, 4:11 gears, wall tuned
HeavyChevySSRS is offline   Reply With Quote
Old 12-03-2015, 03:37 PM   #11
GunMetalGrey
GunMetalGrey's Avatar
Drives: Track prepped 2018 Camaro ZL1 (a10)
That stuff didn't help get rid of my wheel hop (BMR Poly Urethane Subframe, Toe Rod and Trailing Arm Bushings as well as replacing the entire Toe Rods and Trailing Arms themselves)...
I have a negative camber of only -.5 as well in the rear... If anyone has any further suggestions that would be appreciated... Right now I am looking at getting Delrin Subframe bushings... Any thoughts?
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 12-03-2015, 04:01 PM   #12
Bo White
Bo White's Avatar
Your the first Ive heard.
Old 12-05-2015, 09:14 AM   #13
JantzenOKC
JantzenOKC's Avatar
Drives: '13 2LT/RS Twin Turbo
Here's my recipe for wheel hop, minus the poly cradle bushings, they were on backorder. I've never had wheel hop but I've got a CircleD high stall triple disc going in now so I'm taking preventative measures.
3.6L Twin Turbo V6
Garrett GT28 turbos -- Jacfab forged connecting rods -- Diamond forged pistons(10.5:1) -- Alky Control Methonal Injection -- CircleD 2E triple disc torque converter -- BMR suspension
10.75 @ 131mph
JantzenOKC is offline   Reply With Quote
Old 12-05-2015, 10:58 AM   #14
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
I still wheel'd hopped bad last night. They added some of that sticky stuff and heated it up. I thought I was just going to take off but I still started spinning and wheel hopped like crazy. I have bmr trailing arms with bushings and lg motorsports cradle bushings along with the offset diff delrin bushings. Street tires
camarosspower is offline   Reply With Quote
