04-15-2024, 10:13 AM | #1 |
Drives: 2019 Black SS Join Date: May 2009
2019 SS Barely started. Quit after stopping would not restart
Hi,
2019 Camaro bought new orig. battery. Started fine. I let it warm up. Made one stop after about 4 miles, turned the car off. almost did not turn over. So I took it on the expressway. Just before my exit, car began to make some clunking noises. I switched drive modes the same. Came to the top of the exit ramp, car died, would not restart like a dead batter. Wisp of smoke from under the hood. Tried to jump with a Noco and it indicated battery was hot. Towed to the dealer. Any idea? Thanks as always. |
04-16-2024, 10:30 AM | #2 |
Drives: 2023 2SS Convertible Join Date: May 2009
Smoke under the hood? That is not good since the battery is in the trunk. maybe your alternator died?
-Geoff
'12 2SS RS Convertible - Traded in.
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold! '23 2SS Convertible -Same as above except orange. |
04-16-2024, 11:27 AM | #3 |
Let's hope it's that simple.
Don't like the "clunking noise" business. Anyway, battery "hot" sounds like overcharging. Charging should be controlled by the ECM which sends a duty cycle signal to the alternator. Sounds like maybe the regulator bit on the alternator failed and it sent overvoltage to battery. |
