Old 07-06-2020, 10:08 AM   #1
DasBaldDog
Drives: 2017 Focus RS
SOLD: 2014 Camaro Z/28 Red A/C&Stereo
SOLD to a person from Alabama, new owner of Red Z/28 #402
Everyone,
I'm at that time where I'm strongly debating (and 70% of me convinced to) sell the Z/28. Why? Partly because I just don't get to drive it anymore and partly because I purchased a cheaper toy that I am more like to actually take the track like I had intended for this.
Please excuse the water spots/drops in the pictures, I was in a rush to get photos before I had to head to an appointment and didn't dry the car thoroughly after washing.
So the major details,
2014 AC and Stereo.
14425 miles (will go up but its not a daily driver).
Everything is stock unless mentioned.
Red Shiftknob, still have stock unit.
Exhaust flap controller switch which can be removed in <5 minutes
ARH 1 7/8 headers, car comes with stock manifolds as well.
Cammotion Cam. Also includes stock cam.
BTR Valve Springs w/ Titanium Retainers
Morel Lifters
Hardened (and shorter Pushrods), 0.135" side wall, running 0.063" preload (Morel recommends .060-0.075)
Powerbond SFI rated Balancer (stock unit was de-laminating)
ARP fasteners (head bolts, cam bolts, crank bolt)
TR7IX spark plugs
Head/Valve work done by AHP with MS90 Valve Guides, Ferrea exhaust valves, valve job, milled 0.030 for compression, tuned on 93.
GMax RS Tires ~2000 miles or so
Car is available for PPIs, dyno tests, etc. Let me know.
Videos
https://www.youtube.com/channel/UChQ...-Hc1vomvdb5csg
Let me know if you have any questions.
DasBaldDog is offline   Reply With Quote
Old 07-06-2020, 10:32 AM   #2
SS 376
SS 376's Avatar
Drives: 2010 IBM 1SS (Former)
What's your asking price? Not sure I see it above. Thanks.
SS 376 is offline   Reply With Quote
Old 07-06-2020, 10:41 AM   #3
DasBaldDog
Thank you for pointing that out, I updated the original post.
Old 07-06-2020, 06:16 PM   #4
HoodCheck
HoodCheck's Avatar
Drives: 2018 ZLE (M6/hyper blue)
I've been watching yours on fb marketplace since before you started posting elsewhere. I considered yours, strongly...if I wasn't set on getting stock, you would've gotten a call from me. Hell, you still might.
HoodCheck is offline   Reply With Quote
Old 07-07-2020, 03:07 AM   #5
DasBaldDog
No problem.
I would say that it could be taken back to stockish. Due to the milled heads, you'd need atleast SOME cam in it to keep the dynamic compression down but I think there are a ton of sleeper/stealth cams that would keep it more than happy.
That, swap out the headers (sell them on here), I'd keep the shift knob I put on there but if you want stock I still have it... and voila... stock (ish).
But I get your goal, friend.
Let me know if you have any questions I can answer or any thoughts worth kicking around.
Old 07-08-2020, 10:37 AM   #6
HoodCheck
HoodCheck's Avatar
Originally Posted by DasBaldDog View Post
No problem.
If what I have in mind falls through (but its looking really solid at this point), then I'll hit you up. Doubt you'll have it still by then though since you're giving a good deal on it.
Old 07-08-2020, 01:53 PM   #7
DasBaldDog
You never know. I am really interested in keeping it, worked hard on it and it runs great.....
BUT..... I like money too, so I'm torn.
Just let me know, friend.
Old 07-13-2020, 01:10 PM   #8
DasBaldDog
Updated some details (mainly some upgraded/aftermarket parts using re-build of top end).
Old 07-17-2020, 11:33 AM   #9
delphigto
delphigto's Avatar
Drives: 14 1le
Car sounds good. Who tuned it and do you have any dyno numbers?
06 gto Maggie 489 rwhp sold
05 gto ERL/HKE 454 609rwhp na sold
06 Z06 500 rwhp sold
10 2ss ERL 427 530 rwhp sold
14 1ss 1le
delphigto is offline   Reply With Quote
Old 07-17-2020, 01:22 PM   #10
96SS390
Drives: 2006 BOM GTO
15 1lE and some cash??
96SS390 is offline   Reply With Quote
Old 07-18-2020, 04:13 AM   #11
DasBaldDog
No thank you. If I sell it, its mainly to either go after a new experience or to open a hole in the garage.
Old 07-18-2020, 04:15 AM   #12
DasBaldDog
Thank you.
SpartanLSX tuned the car (they seem to do a fair number of LS7's in the area), they did the tune after the head/header/cam install, and recommended that I change to the colder plugs (which I had in my mind to do already) and then spiffied up the tune after I put the new plugs in (he said they got a few more degrees of timing without tickling the KR)
No dyno numbers but similar setups without the milled heads do 550-560 wheel, so I'd guess another 10-15 with the milled heads.
If you are interested and want a dyno as part of a PPI, I will make the car available to any accredited/capable shop.
Old 07-24-2020, 09:58 AM   #13
DasBaldDog
Sale Pending. Will update as Sold/Not Sold later.
