11-07-2017, 07:58 PM | #43 |
Drives: 2017 Camaro 1SS Join Date: Apr 2017
Anyone definitively know how much the stock 1ss cloth seats weigh?
12-04-2017, 02:34 PM | #44 |
Drives: New : 2017 SS 1LE Old: 2012 TTRS M6 Join Date: Oct 2015
1LE Recaros weigh 55 lbs... I would guess about 50 lbs considering they still have similar power adjustments...
. https://www.wheelwell.com/profile/56...ed9c3a/garage/ . . Project 1LE Wraith: http://www.camaro6.com/forums/showthread.php?t=474068 |
03-23-2018, 07:53 PM | #45 |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
Stock SS m6 driveshaft 24.4lbs.
Gforce 3.5" Aluminum 20.8 This included all bolts and flanges associated with each. Note, forgot to add the carrier bearing for the stock shaft
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
04-01-2018, 06:31 PM | #46 |
The Mechanic
Drives: 1SS M Join Date: Dec 2017
Are these weights going to be consolidated into the first post? it's great info but scattered all over the place
05-08-2018, 03:27 PM | #47 |
Drives: 2016 Camaro 1SS Join Date: Feb 2017
Removed from my 1ss the non-bose rear quarter panel speakers and insulation from both sides behind those speakers= 6lbs total. They sounded like garbage anyway and other than shifting the sound stage forward aren't missed lol.
Also. the weight of the stock intake manifold(no throttlebody)/plastic top cover/camaro side engine covers was 15 lbs. I do believe the MSD atomic force I replaced it with was a few pounds heavier (intake only, no engine covers or throttlebody). I didn't weigh it but one of the retailer sites for it claims 18lbs and I'd believe it.
1. Phastek detachable front license plate bracket 2. Blacked out Bowties 3. Blacked out sidemarkers/third brakelight 4. Rotofab dry/no soundtube CAI 5. VMAX ported throttlebody 6. Kooks 1 7/8 Longtubes with Hi-Flow Cats 7. EFI Tuning Flex Fuel kit and tune 8. HP Tuners NGAUGE 9. Zeitronix ZT-2 Wideband(reads on NGAUGE) 10. Ported MSD intake manifold 11. CORSA XTREME axle back w/ dual quad black tips
12. Racestar Darkstars 17X9.5 with Mickey Thompson ET Street SS 305-45 17 Radials 13. Kicker 3-way door speakers. DYNOCOM mobile dyno trailer: 471hp/490TQ@97degrees ambient/ethanol percentage=80% |
06-25-2018, 07:11 PM | #48 | |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
FYI... 2016 Convertible 2SS Leather Rear seat (non-folding back & bottom) 23lbs
NPP, MRC, Tinted side & rear reflectors, OEM ZL1 Rockers / 3rd Brake / Darken tail lights, OEM Blk rear splash guards, Satin hood wrap, Fuse pull, Sound tube delete, Cat delete, Ported 95 TB, Ported MSD IM, Dry RotoFab, ARH 1 7/8 headers, E85, "Performance Dyno" Tune, BMR "pieces", "Track" alignment, Hawk DCT-70/70's w/SRF, Goodridge lines, Ti shims, Red powdered calipers, 18" APEX SM-10's w/ Pirelli DH's, FE4 Vert swaybars, Brake cooling ducts, ATI 10% UD, Vorshlag camber plates, OEM 1LE Splitter w/APR Ext., Velossa BIG MOUTH Ram Air, CF QA1, ZLE brakes(F)
01-23-2019, 12:21 PM | #49 |
Drives: C5 Join Date: Nov 2018
This is not directly related...but has anyone weighed in AFTER the lightning mods?
I'm really curious how light we can get the gen 6 to? is 400lbs doable? 300? |
01-23-2019, 01:28 PM | #50 |
BAMF SS
Factory trunk = 25 lbs
Anderson composite trunk = 8 lbs
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
01-23-2019, 01:30 PM | #51 | |
BAMF SS
Still have a kirky seat, front drag brakes and a few other things to do. Should be right at 3100 lbs at the beginning of the season.
01-23-2019, 02:36 PM | #52 |
01-23-2019, 03:53 PM | #53 |
BAMF SS
Rear seats removed
Passenger seat removed Factory driver seat
01-23-2019, 07:49 PM | #54 |
Drives: 2017 SS 1LE Join Date: Mar 2016
Is your factory trunk wait w/ the SS spoiler on it? if so I wonder how much weight the spoiler adds, either way that's a huge difference!
IG: @NC_M1SS1LE
01-23-2019, 08:14 PM | #55 | |
BAMF SS
Latch and 3rd brake light removed
10-05-2019, 07:54 PM | #56 |
Horsepower whisperer
Drives: Camaro Join Date: Jun 2017
2016 stock exhaust manifold, primary cats, and 2nd cats cut 6” after cats = 65lbs
Tsp and kooks headers and pipes are ballpark 1/2 or more of that |
