06-24-2022, 03:59 PM | #1 |
15k miles 416 long block *sold*
*theft recovery*
Powerbond underdrive pulley TSP custom 243/255-110 camshaft Johnson 2116 link bar lifters PRC 13* 260cc cylinder heads milled .035" Eagle #12946 416ci rotating assembly Clevite H bearings ARP 2000 rod bolts ARP main studs ARP head bolts ARP cam bolts Mast stroker windage tray Rings gapped .024/.020 for 200 shot. Never sprayed. 12.6:1 compression Powell trunion bushings Melling 10295 pump with COPO spring TR7 plugs Holley Aluminum LS Valve Covers (Black Crinkle Finish) Shortblock assembled by Terry Wilkes at Wilkes Performance. $8500
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X Last edited by Bo White; 06-26-2022 at 04:01 PM. |
06-24-2022, 04:34 PM | #2 |
Damn Bo you going to part the car out? What did the insurance say?
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
06-24-2022, 04:37 PM | #3 |
Might be cheaper to go this route than build my own engine...
2011 2SS/RS Convertible, Victory Red, Roto-Fab CAI, Stainless Power 1 7/8 headers, No Cats, Straight piped, Bo White TB, ZL1 CONVERSION, CDC Roll bar and some powder coating and dipping.
06-24-2022, 05:44 PM | #4 |
No doubt. Would cost you $13k or so to build new.
06-25-2022, 06:53 PM | #5 |
Sold
