05-16-2022, 07:19 PM | #1 |
C8 ECU Finally Cracked?
05-16-2022, 07:40 PM | #2 |
Thank you Al Oppenheiser!
“We adjusted the air to fuel ratio, ignition timing advance, DI injection timing, DI rail pressure, and variable cam phasing angles. We confirmed that our calibration changes were in fact taking effect, but none of them led to measurably significant power gains.”
more info here: https://www.midenginecorvetteforum.c...%E2%80%99s-ecm |
05-16-2022, 08:03 PM | #3 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
Companies make big claims all the time (Vararam ZL1 intake ring a bell). Until a product is delivered into the hands of consumers, I will remain a skeptic.
05-16-2022, 08:24 PM | #4 | |
I run a Trifecta tune on my daily driver GMC Canyon and its quite impressive for a canned tune. |
05-17-2022, 02:56 AM | #5 | |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
05-18-2022, 12:13 PM | #6 | |
Coupe Newbie
Someone feels Trifecta's announcement may have just screwed the community. Watch...
05-18-2022, 01:59 PM | #7 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
I guess I am a little confused about the C8's ECU being hacked, so to speak. There is a local guy with a C8 and a set of twin turbos pushing over 800 HP, not sure if that is RWHP or crank. It has a custom intake manifold and i believe different injectors. The car was built by Cicio Performance. I can only assume this set up required a tune. Let me know if I am wrong; I thought the ECU was already cracked on the C8.
05-18-2022, 02:31 PM | #8 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
They were probably running a piggy back computer. It’s a computer you run in line with the stock ECU but allows you to change some of the parameters, without having access to the factory computer.
05-18-2022, 02:44 PM | #9 |
Recalled user
Drives: '12 Camaro SS, '18 Colorado Z71 Join Date: Mar 2009
Did it help with shift points? Happen to have a dyno before/after? I'm interested b/c the lazy shift points/responsiveness for MPG annoy me on my Colorado.
2012 2SS 45th AE LS3 M6 Borla ATAK Catback Kooks Stepped LT Headers CAI Intake Hexvents VMAX CNC Ported Throttle Body RX Catch Can Hurst Short Throw Shifter Pfadt ZL-Spec Stage 3 Suspension Forgestar F14 Tuned by Frost |
05-18-2022, 05:10 PM | #10 |
05-18-2022, 05:59 PM | #11 |
All Cicio performance builds I have seen they have ran a second ecu. They make some bad ass rides.
05-18-2022, 09:15 PM | #12 |
Drives: '11 2SS/RS LS3 M6 (Sold) Join Date: Dec 2015
A stand-alone ECU is going to be the best option for modding any new cars in the future. The performance automotive industry is slowly becoming a thing of the past.
2011 IOM 2SS/RS LS3 M6- Injen CAI, TSP 1 7/8” headers, PTB, Hurst short throw, Corsa catback exhaust, 20" TSW Nurburgrings, BMR lower control arms, BMR tunnel brace, Hotchkis lowering springs. 3660lbs. Tuned by me (sold)
2010 RJT 1SS/RS LS3 M6- CAI, TSP 2” headers, TSP F-35 cam, PTB, Hurst short throw, Dronemaster catback, BMR lowering springs, Kirkey seats, 20”/18” Weld Belmonts, 3550lbs. |
