11-08-2021, 04:49 PM | #1 |
2011 camaro 3.6 V6 dad
HELP! son's Camaro does not always start
his 2011 v6 3.6L recently has had issues starting. I replaced the battery after it wouldn't start up at his school. It started right up. I took the "old" battery to be tested and it still good with plenty of cranking volts. Next day the car would not start on first key turn. All the lights, wipers, horn worked fine. Tried again and it started. I'm thinking the starter or ignition..? Could it be the starter relay or solenoid? We need some help in troubleshooting - Thank you
11-08-2021, 06:32 PM | #2 |
Some basic info... is it a crank but no start, or it doesn't crank at all when key is turned to start ?
11-08-2021, 08:42 PM | #3 |
no crank - no click - it just started fine a few minutes ago...? thank you for taking the time....
11-08-2021, 08:58 PM | #4 |
Drives: 2011 Camaro SS LS3 Join Date: Oct 2020
Take it to a local auto parts store and have them test the starter on it. It’s getting cold and that can put added stress on the starter and possibly send it over the edge.
https://youtu.be/d-azByCKQMY This video should be helpful for you. One tip is if you’re ever in a pinch and your starter doesn’t work, you can lightly tap it and see if it’ll start but it’s not a guarantee. Take care, hopefully your son can have his sweet ride back!
2011 2SS/RS 6M: Hurst Short Throw Equipment, Speed Engineering Headers, Spectre CAI, BTR Stage 3 Camshaft 229/244 .630"/.615" 113+4, Chromoly Pushrods, .660" Springs with steel retainers.
11-08-2021, 09:07 PM | #5 | |
Drives: 2015 zl1 m6 Join Date: Jan 2020
Good tip !. But I’d say if you tap the starter then it starts well then I’d say you found the culprit . Either starter motor going bad or is bad electrical connection .. |
11-08-2021, 09:07 PM | #6 |
The issue started recently. I just went out and started his car with no issue. This morning he had the same no start problem 2 times then turned the key a 3rd time and went off to school. Started for him 1st turn after practice.
11-08-2021, 09:11 PM | #7 | |
Just to double check have you verified this battery sits at or above 12 volts when it’s sitting? Something to check to make sure all ducks are in a row. Wouldn’t suspect it however if you’re not hearing any clicking on start up.
11-09-2021, 12:25 AM | #8 |
Battery is New. I was also told that the battery that I replaced is also still good. Shop manager “this battery will start a semi”.
11-09-2021, 12:26 AM | #9 |
Battery sitting at 11.7 turned the key and went to 14.7
11-09-2021, 03:06 AM | #10 |
It don’t come easy.
A normal battery at 11.7 would be considered toast. Anything below 12.5 is already on its way out. Either that, or something is drawing down the battery while it is sitting.
11-09-2021, 04:30 AM | #11 |
My error it is sitting at 12.7
11-09-2021, 07:29 AM | #12 |
You are going to have to start tracking voltages through the system. I would start at the starter solenoid and see if you are getting voltage there when trying to start it. Of course an intermittent electrical problem can be a real pain to track down.
11-09-2021, 07:42 AM | #13 |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
Look at the starter and the connection to it and ground.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
11-09-2021, 09:22 AM | #14 |
Drives: 2012 Victory Red LFX Join Date: Dec 2012
I had a bad positive battery cable on another car that did that exact same thing. Sometimes started fine, sometimes nothing.
Thread Tools | |
