Old 10-20-2019, 09:50 AM   #1
7speed
Drives: 21 SS
Will Stock 18s fit
Does anybody know if the stock oem 18s will fit the front 6 piston calipers on our cars? I can get 2 for cheap and thinking of using 2 upfront as a drag setup (I know not a drag cars haha) since the height matches my current rear drag setup.
7speed is offline   Reply With Quote
Old 10-20-2019, 10:16 AM   #2
7speed
Drives: 21 SS
Scratch this, I dug deeper and found out they fit.
Old 10-23-2019, 10:33 AM   #3
7speed
Drives: 21 SS
Winter setup done
Old 10-23-2019, 10:42 AM   #4
NeverDie
Drives: 2017 Camaro SS 1LE
Tires sticky AF, holding it on the ceiling!
NeverDie is offline   Reply With Quote
Old 10-23-2019, 10:43 AM   #5
camaroJD
Drives: 2019 Satin Steel 1SS 1LE w/ PDR
Nice, I have the exact same ones but I plastidipped them black
camaroJD is offline   Reply With Quote
Old 10-27-2019, 12:55 PM   #6
7speed
Drives: 21 SS
Yeah good idea...........lol
Old 02-23-2020, 09:52 AM   #7
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
I'm assuming you both are running 245/50/18 tires front and rear on these wheels. I'd like to do the same setup for winter tires. Are you having any issues with traction control, ABS, or any other nannies getting confused by the equal tire diameters?
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 02-23-2020, 11:23 AM   #8
samr350
samr350's Avatar
Drives: 2017 SS 1LE
I've been running 245/50/18 square for the past two winters with no issues. Tons of people run a square setup on the track as well without problems.
samr350 is offline   Reply With Quote
Old 02-23-2020, 12:19 PM   #9
Msquared
Msquared's Avatar
Thanks. That's what I figured, because there is only 0.4" difference in diameter between the stock front and rear tires anyway...and because obviously the base models run same-size tires front and rear all the time. There's just always that one person that says even the slightest change will trip up the nannies.
Matt Miller
2020 SS 1LE
Old 02-23-2020, 12:21 PM   #10
sonic1971
Drives: 2SS 1LE 2018
Do you know if that setup would also work on a 1LE?
sonic1971 is offline   Reply With Quote
Old 02-23-2020, 06:54 PM   #11
samr350
samr350's Avatar
Drives: 2017 SS 1LE
Considering that they're on a 1LE, yes I'd say it probably would work.
Old 02-24-2020, 10:30 AM   #12
Matos1LE
Drives: SS 1LE
ROFL
Matos1LE is offline   Reply With Quote
Old 06-23-2020, 06:26 PM   #13
Vaska
Drives: On Hiatus
Bope
Vaska is offline   Reply With Quote
Old 12-06-2020, 05:12 PM   #14
Vaska
Drives: On Hiatus
245/50/18 on 18” RS wheels, anyone have issues with the tires rubbing on something in wheel wells during full lock?
