07-25-2019, 01:00 AM | #1 |
Drives: Silver 2014 Camaro 2SS Join Date: Dec 2018
Week 2 with new CAM
So I’ve put almost 2000 miles on it and I love the cam. Buuuut I hate the stall lol. TS recommended the 3000-3200rpm stall. I’m wondering if it would hurt anything to go down to a 2400 stall?
Also, my last dyno run/tune after cam install, wasn’t as impressive as I was expecting. So full bolt-ons, TS stage 3 vvt cam, e85 flex fuel kit and the best pull was 440rwhp. Nearly $10,000 in mods for 125 rwhp from stock? Maybe my expectations were too high. Tried to upload a vid of a start up. The car sounds wicked now. But it wouldn’t load. 🤷*♂️🤷*♂️ |
07-25-2019, 03:26 AM | #2 |
Drives: Miss Con Ception Join Date: Aug 2016
Did you swap to a 3.91 screw?
That cam is designed for high RPMs.
2011 1SS/RS LS3 CGM
07-25-2019, 05:58 AM | #3 |
Started#gottalovethatblue
I assume you have supporting mods beyond just the cam? (Headers, cold air intake, etc.) That being said, 125hp over stock on a cam is some seriously solid gains. You might be able to get higher numbers out of some ported and milled heads, but that’s more $$ I’m sure you don’t want to spend. If you don’t have the supporting headers, etc. that too would yield you more power. As for the converter, I can’t give you advice there, but I know TSP does their homework for what mates up best to their cam. You may get the car pushing through your brakes or bucking at low idle with a smaller stall speed.
07-25-2019, 06:47 AM | #4 |
Drives: 2011 Synenergy Green 2SS/RS Join Date: Jan 2011
What converter do you have?
What do you hate about it? I have a yank 2800 stall and it drives like a stock unless you are on it. I am thinking about sending it back to get it stalled to 3600.
2011 Synenergy Green 2SS/RS Automatic.
07-25-2019, 07:42 AM | #5 |
07-25-2019, 07:46 AM | #6 | |
The low RPM buck is already there. My buddy has nick named the car “Twitch”. |
07-25-2019, 07:55 AM | #7 | |
Drives: 2014 2SS/RS Join Date: Jan 2018
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
07-25-2019, 07:59 AM | #8 | |
Edit: sorry, didn’t really directly answer your question. What I really don’t like about it is the power isn’t instant for DD until the stall locks in. So just speeding up to pass someone at normal speeds RPMs just jumping all over the place. Now when I’m out romping around keeping the RPMs about 3500, it’s a jet on wheels. But that’s not 24/7 for me lol. |
07-25-2019, 08:04 AM | #9 |
The e85 kit was only a few hundred and nets close to what porting the heads would do on NA for way cheaper. So I don’t feel like that was too bad of a deal. What ran the cost up was doing the AFM/Dod delete and Stall. If it was a manual I would have saved $2000ish just right there. Plus I wouldn’t be losing 20% in the transmission. Even so, I was expecting closer to 460ish. It was like 98 degrees that day and I got my e85 from the “bad” station in town. It was really about e40.
07-25-2019, 08:16 AM | #10 |
USA-1
Maybe your tune is off. I'm not cammed yet, but my FBO, 3.91, 3200 stalled L99 is wicked fun and I DD it. It does take a bit more to get it going, but it isn't bad.
I think that flex fuel kit was a waste. Do you have a ported intake manifold? Underdrive pulley?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
07-25-2019, 08:24 AM | #11 | |
Okay so if you didnt upgrade the fuel pump and injectors as you would need to then yes it's only a few hundred. My guess is that if you were running true E85 you have maxed out your fuel system on the dyno. Also 440 is respectable for an auto car Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
07-25-2019, 08:29 AM | #12 | |
And yes, I’ve questioned my tuner because I also think something is off in the tune. The first week I kept getting a CEL flash on when just cruising. He said the car was thinking its detecting a misfire, but blamed it on the cam. He went back and checked plug gap and did something else to it. It’s only happened once since then. So I don’t know. Might bite the bullet and have it returned at a different shop. |
07-25-2019, 08:42 AM | #13 |
Drives: 2011 Camaro SS Join Date: Jul 2017
I have a 3500 stall and yes its noticeable but still very driveable. It's your tune for the tranny. I drive mine daily and it acts mostly like a stock converter until I nail it. The 6L80 is very finicky for the tune.
07-25-2019, 08:59 AM | #14 |
Drives: 2014 2-SSRS Slushbox Join Date: Sep 2018
Damn...I wish I was pushing 440hp...but $10k?
Sorry, don’t have anything to add, I’m here learning the platform from our awesome members here. |
