06-17-2016, 07:09 PM | #1 |
Todd
NEED HELP WITH AXLE NUT
sooo I'm doing a diff and axle swap and need to take off the hub/axle nut but the nut is held on by the hand of god... I broke a big breaker bar, and a giant torque wrench (i know its not the right tool but i thought i cracked it loose when i broke the breaker) so heres my question, what do i do to get this thing off... i use aerokroil, (its insane stuff, i highly recommend using) but that didn't work for me lol i used a 25inch breaker and 5 foot bar and nothing. my car was in park and the ebrake on, i am curious if this may have something to do with it. am i missing something? i can take it to a shop i work at for heat but only want to use the torch as a last resort. any help is appreciated. thank you
06-17-2016, 08:21 PM | #2 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
Reverse threaded? You can stop the earths rotation with a 5' cheater pipe
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
06-17-2016, 08:23 PM | #3 |
Camaro: A Legend Reborn!!
Maybe this helps? Like you said, heat as the last resort.
[SIGPIC][/SIGPIC] |
06-17-2016, 08:24 PM | #4 |
06-17-2016, 08:26 PM | #5 |
06-17-2016, 08:30 PM | #6 |
It is a adobe file of the install/removal procedure. Not a picture.
[SIGPIC][/SIGPIC] |
06-17-2016, 08:34 PM | #7 |
4b. For vehicles equipped with the high performance brakes (Brembo) proceed to step 4c. All other vehicles proceed to step 4g.
Note: DO NOT place the drift or flat bladed screwdriver against the bottom of those vehicles equipped with the high performance brakes (Brembo). Damage to the bottom cross over tube could be damaged causing brake failure. 4c. Insert a drift or large flat bladed screwdriver (3) in the cooling fins of the brake rotor against the brake caliper (1). 4d. Place a clean shop towel (2) between the drift or large flat bladed screwdriver (3) brake caliper (1). 4e. Using a breaker bar (5) and the proper size socket (4), loosen the wheel drive shaft nut.
[SIGPIC][/SIGPIC] |
06-17-2016, 08:36 PM | #8 |
Thank you for the help! I have brembos but I have a v6.
06-17-2016, 08:40 PM | #9 |
It would be better to have a impact gun. It should go with a breaker bar though
[SIGPIC][/SIGPIC] |
06-17-2016, 08:41 PM | #10 |
Have a impact. Didn't get anywhere. Silly question, is this by chance a reverse thread ? I don't think it is but I'm lost lol
06-17-2016, 08:46 PM | #11 |
. No..it is not reverse thread and it is on there. Spec is 200 lb ft.
[SIGPIC][/SIGPIC] |
06-17-2016, 08:48 PM | #12 |
Ok! So one last thing kind man, should I keep the car in park or neutral? Should I keep the Ebrake off or on?
06-17-2016, 08:48 PM | #13 |
If your on the drivers side and your loosening it you want to go counter clockwise.Lefty loosey-righty tighty
[SIGPIC][/SIGPIC] |
06-17-2016, 08:49 PM | #14 |
Ebrake on and follow my instructions I sent above. Post 7
[SIGPIC][/SIGPIC] |
