Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 04-29-2016, 03:13 PM   #1
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS
Thumbs up Megan Coilovers @ Phastek Performance
NOW AVAILABLE!!
FREE SHIPPING @ Phastek Performance
Coilovers will greatly improve the ride and looks of your Camaro. They work out great if you plan on tracking the car, the fluid transfer is much faster then the stock strut, they are much lighter then the factory struts, and they allow you to choose where you would like the car to sit. Check out the different options that Megan has for your combination, they have everything from full Race set up to a Street set up!!
Megan EZ-Street Coilover set #MR-CDK-CCA10-EZ
Fits:
2010-2013 Camaro (Non ZL1 or Magnetic Ride Equipped cars)
Springs Rates:
F: 8kg/mm
R: 12kg/mm
Features:
  • 15 Levels of Adjustable Damper Strength
  • Aluminum Brackets paired with rubber inserts
  • Rubber Dust Covers
  • Adjustable Ride Height
  • Conservative Spring Rates
  • Single-Cylinder Design - mono-tube
  • All coil-over damper kits come with 1 year manufacture-defect warranty.
  • All Hardware is Included (Reuse OEM top plates)
Megan Coilover set #MR-CDK-CCA14
Fits:
2014-2015 Camaro (Non ZL1, Z28, or Magnetic Ride Equipped cars)
SPRING RATES:
F: 8 kg/mm
R: 12 kg/mm
Features:
  • 32 Levels of Damper Force Adjustment
  • Rubber Dust Boot
  • Aggressive Spring Rates
  • Aluminum Brackets
  • 32 Levels of Adjustment:
    -1-8: Suggested for track use.
    -9-16: Suggested for mountain/aggressive use.
    -17-32: Suggested for common street use.
  • All coil-over damper kits come with 1 year manufacturer-defect warranty.
  • Must re-use the factory top hats for this application.
Megan Spec-RS Coilover set #MR-CDK-CCA10-RS
Fits:
Springs Rate:
F: 8kg/mm
R: 12kg/mm
Features:
  • External Reservoir for additional oil capacity and separate compression adjustment (New feature)
  • Rubber Dust Boots
  • Dual-Cylinder Design
  • Steel front brackets/ Aluminum rear aluminum Brackets
  • 32 Levels of Damper Force Adjustable; Separate Compression and Rebound adjustments.
Sales@Phastek is offline   Reply With Quote
Old 07-01-2016, 04:42 PM   #2
Sales@Phastek
Drives: 2016 1SS
Old 08-19-2018, 10:04 PM   #3
Blown1LE
Blown1LE's Avatar
Drives: 2015 Supercharged Camaro 1LE
Does these fit the 2015 1LE ?
Magnuson Supercharged 2015 1LE RS/2SS. Texas Speed Stage 3 Blower Cam. DSX Aux Pump. e85 Flex Fuel Kit. BMR Suspension. On Instagram @wakeyourneighbors @Blown1LE
Blown1LE is offline   Reply With Quote
coilover, megan, megan coilover, phastek, phastek performance
