08-05-2018, 05:12 PM | #1 |
Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
Directions for catch can with Magnuson?
Anyone have a Mishimoto catch can with the Maggie? Pictures or helpful guidance would be appreciated.
2017 Camaro 2SS vert - Nightfall Gray
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance Last edited by Drsagacity; 08-05-2018 at 05:38 PM. |
08-06-2018, 08:09 AM | #2 |
Drives: 2017 Camaro 1SS M6 (SOLD) Join Date: Oct 2016
Have one with a Whipple.....hooked up same as before.
2017 1SS M6 Hyper Blue Metallic NPP, MMR 228 Z/28 replica wheels, Front: 20 x 9, Rear 20 x 11
Stock: 416hp/427tq, 12.21 @ 116.80 Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft. Tuned by EFX Tuning 688hp/632tq Best 1/4 to date: 10.705 @ 131.92 |
08-14-2018, 07:25 PM | #3 |
I will take some pictures. The hoses that came with the kit obviously didn't work, but I like the way we set it up. It is in front of the engine bay and really easy to access. Will take pictures in the next couple days.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
08-14-2018, 07:49 PM | #4 |
Sitting at my daughters soccer practice and grabbed a few pictures.
08-14-2018, 09:26 PM | #5 |
You ideally need a different catch can for a FI setup...it needs to have a check valve with a breather so it can vent crank case pressure to atmosphere under boost. If you don't, you will start pushing seals out of the engine at higher boost levels.
2016 NFG 1SS A8
08-15-2018, 01:07 AM | #6 |
I have a breather on the other side replacing the oil cap. What does that do?
08-15-2018, 08:09 AM | #7 |
If it's a breather with a check valve then you are good.
2016 NFG 1SS A8
08-15-2018, 01:09 PM | #8 |
Yep. It replaces the oil cap.
08-20-2018, 06:24 AM | #9 |
What breather with check valve do you have? I have a mishimoto catch can with a whipple and i feel i need to upgrade the can or add the breather with check valve.
08-20-2018, 07:13 AM | #10 |
08-20-2018, 07:16 AM | #11 |
I have a Metco breather. Got it from Ted Jannetty
Baby Blue
05-22-2021, 04:51 PM | #12 |
Camaros of NorthWest Ohio
Drives: 2012 LS Join Date: Oct 2015
The 2 hoses on the catch can were do they run to?
The hose from the valley goes to the intake behind the tb on the Maggie so u can't use that one.
2012 ls 20in rims,cai,oil catch can,throttle body spacer,billet grill,axle back exhaust,vitesse throttle control,red oracle headlight halos, red oracle afterburner taillights,blacked out windows,oem strutt tower brace polished and painted
