Old 11-19-2011, 01:10 PM   #1
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
Weld Racing RT-S
Fed Ex delivered my new 17" Weld RT-S wheels yesterday that I bought from McCormack Racing (see my review in the vendor feedback section). Yes, these are the 17x10 and 17x5, as recommended in the Weld fitment guide. But just wanted to say that I am thoroughly impressed with the quality and craftsmanship of these wheels. They look awesome!!! Initially, Weld Racing told me their RT-S wheels were not compatible with TPMS systems, but I discovered that if I used a Dill Air Controls all-metal valve stem (P/N VS-925C) and flipped the sensor upside down, it works great!! I can see that I will definitely need to tie back the emergency brake cables in the rear. And hopefully, I won't need to notch my rear LCA's if I keep my rear ride height at or above OEM height. I plan on getting the new BMR adjustable LCA's when my budget permits, but that probably won't be for a while. As it sits right now (suspension fully extended), I have about 3/4" between the rear LCA and the inner lip of the wheel. Just thought I'd share some pictures and say that I am very happy with my decision to go with the Welds.....(so far). NOW I JUST NEED TIRES!!!
blazzin1 is offline   Reply With Quote
Old 11-19-2011, 02:18 PM   #2
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
Those look amazing... I've been looking at Weld wheels....
Do you know if this or a similar style is available in a 16 inch by say 10 or 11 inch wide wheel...
I'll replace the rear brakes...
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
Old 11-19-2011, 02:37 PM   #3
blazzin1
blazzin1's Avatar
Thanks for the compliment. Unfortunately, the RT-S wheels are not available in 16", they jump from 15" to 17". I think Bogart is the only manufacturer that makes a 16" that fits with the V6 brakes. Maybe CCW too?!?!?
Old 11-19-2011, 02:48 PM   #4
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Those look great. How much clearance around the Brembo calipers? I thought 18's were the smallest you could go.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein
PAUL SS is offline   Reply With Quote
Old 11-19-2011, 03:06 PM   #5
those are going to look awesome
Old 11-19-2011, 05:19 PM   #6
blazzin1
blazzin1's Avatar
Nope, 17" is as small as you can go without changing the brakes, but I think Weld and Bogart are the only 17's that will fit. To answer your question, I have about 1/4" between the outside of the caliper and the inner barrel of the wheel, and probably about 3/8" between the front face of the caliper and the back of the spokes on the wheel. However, If you're lowered at all, you will need to either notch your lower control arms or buy BMR's new LCA's which have pretty much been designed to be compatible with these exact wheels.
Old 11-19-2011, 05:51 PM   #7
Boost6924
Drives: 2SS/RS
I have these same wheels on the back. My car has Eibach lowering springs. Droppd maybe 1 1/4". Still running unmodified stock lower control arms. E-brake cable tie down was the only mod needed. Thanks for pics, i need to order the front wheels next. That thing will look awesome!
438cid IPS Twin Turbo.
Boost6924 is offline   Reply With Quote
Old 11-19-2011, 06:47 PM   #8
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
I love those wheels. Thanks for posting pics!
Squintz Palladoris is offline   Reply With Quote
Old 11-19-2011, 06:55 PM   #9
Squintz Palladoris
Yep, CCW will make a set. Same ballpark as the Bogarts. I really wish Weld would step up and offer a 16" for the rear. Plenty of Bias Ply and Radial tire choices in a 16".
Old 11-19-2011, 07:37 PM   #10
Camarowguy
Camarowguy's Avatar
Drives: 2011 imperial blue SS, black 92 RS
Couple questions if you don't mind. What is the weight and what is the cost? Thx
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :(
2017 Silverado 5.3 all stock
2004 5.7 GTO 78mm turbo
Camarowguy is offline   Reply With Quote
Old 11-19-2011, 08:17 PM   #11
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
the weld wheels are nice but if your lowered and leave the line hard they will hit the lower arm hard.
94guy is offline   Reply With Quote
Old 11-19-2011, 08:20 PM   #12
SlowSS
SlowSS's Avatar
Drives: 2013 Camaro 2SS/RS 1LE
Those are going to look real good!
SlowSS is offline   Reply With Quote
Old 11-19-2011, 08:58 PM   #13
bpoirier
bpoirier's Avatar
Drives: 2SS/RS IOM CGM Stripes
Awesome looking wheels. You definitely made a great choice.
bpoirier is offline   Reply With Quote
Old 11-19-2011, 09:02 PM   #14
Squintz Palladoris
Not with the proper arm they wont.
Discounts for our Military Personnel from MTI Racing MTI Racing Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 07-07-2010 12:22 PM
