02-10-2019, 11:17 AM | #1 |
Xtrons te103ap
Has anyone installed this head unit (xtron te103ap) in there camaro, I was going do a kenwood but I found this android stereo with a 10.1 screen, quality yes its Chinese so that will be a gamble but on the good side is you can use track addict and a lot of other performance apps, if I end up taking the risk I will be using a pac install kit
Cai intake and a few other mods😎
02-10-2019, 11:18 AM | #2 | |
Drives: 2012 Camaro 45th Anniversary RS Join Date: Nov 2012
I don’t know what it looks like but the pac kit only works with a 7” screen. Your going to have to cut and fabricate to make it work. If you don’t need a cd/dvd player, get a mechless unit. Having the extra space behind the radio will definitely help you |
02-10-2019, 11:21 AM | #3 |
I would count on how deep the pac sets the radio back to cover the hinged area on the new hu, just not sure how well it will blend in with all the curves, may be able to get it to look great or may not, included picture to show the inset depth
02-10-2019, 11:22 AM | #4 |
02-10-2019, 11:27 AM | #5 |
Here it shows the hinged system
02-10-2019, 11:30 AM | #6 |
02-10-2019, 11:35 AM | #7 |
I'm more worried about the vents, it definitely wouldn't be a straight install that's for sure going require some custom trim
02-10-2019, 12:00 PM | #8 |
Poor phone photoshop
02-20-2019, 06:26 PM | #9 |
This is a quick mock up, I still need to cut the back out and line routing
02-20-2019, 09:33 PM | #10 |
Drives: 2013 L99 Join Date: Jan 2019
Not a bad look. Let us know how it goes.
02-25-2019, 06:55 PM | #11 |
Drives: 2010 Camaro 1LT 6-SPD Join Date: Nov 2018
I did an install with a large screen from Joying. I flush mounted the display to a Metra dash kit. This Joying model has a screen that attaches with removable mounting pads and connects via a ribbon cable. I had to use some metal brackets I had lying around and I Dremeled a channel in the bezel. I also had to do some trimming of the bezel to fit the screen.
Sent from my Z2_PRO using Tapatalk |
02-25-2019, 06:59 PM | #12 |
Looks good, I'm waiting for a few cables on mine to complete my setup The only issue is I'll need to figure out how to lock the screen with the adjuster screws but ill give that thought as soon as I get all the cables required to finish the job
02-25-2019, 07:28 PM | #13 |
This is what it looks like behind the screen
02-25-2019, 07:30 PM | #14 |
If you are looking for an integrated dash cam solution, this is the one I bought:
US $20.02 10%OFF | Junsun S500 ADAS Mini Car DVR Camera Full HD LDWS Auto Digital Video Recorder Dash Cam for Android Multimedia player https://s.click.aliexpress.com/e/bzuUWa5a It includes and app that is always running and allows you to view the camera on the head unit. You still need a microsd to record to though. Sent from my Z2_PRO using Tapatalk |
