Old 03-20-2018, 01:11 AM   #1
Goohead
Horsepower whisperer
Drives: Camaro
Factory 5 spokes rear to front?
Will the factory 5 spoke wheels on the ss with 275 tires move from the rear to the front without issues? Or is the offset wrong?
Goohead is offline   Reply With Quote
Old 03-20-2018, 06:37 AM   #2
Redlinez
Shifts under load
Redlinez's Avatar
Drives: 2020 Camaro 1SS 1LE rally green
There is quite a bit of offset difference.
24 Audi S3 prem plus, sport package
HPDE - southeast - JTI- solo, PCA- blue.
22 Suzuki GSX-S 1000GT blue
Redlinez is offline   Reply With Quote
Old 03-20-2018, 07:39 AM   #3
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Yup, there's a lot more offset in the rear than in the front. If there aren't any issues with the spokes clearing the calipers, there's a good chance you'll have issues with the tire or barrel rubbing the strut or knuckle.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 03-20-2018, 09:38 AM   #4
Camaroguy555
Drives: SUMMIT WHITE 2016 1SS NPP 6MT MRC
When I was running four rear wheels with 285s I needed a 15mm spacer to clear the strut.
Camaroguy555 is offline   Reply With Quote
Old 03-20-2018, 02:07 PM   #5
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
https://www.willtheyfit.com/index.ph...9-5&offset2=39
mjk3888 is offline   Reply With Quote
Old 03-20-2018, 02:48 PM   #6
solarstingray
Drives: 2014 c7 corvette and 2017 camaro ss
might work some one give it a shot !! LOL
solarstingray is offline   Reply With Quote
Old 03-20-2018, 02:57 PM   #7
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Minimum 10mm spacer. 15 is best.
New studs needed.
BradfordCamaro is offline   Reply With Quote
Old 03-20-2018, 03:43 PM   #8
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
definitely won't fit without spacers. Not worth the trouble in my opinion.
