Old 06-06-2012, 09:42 PM   #1
LoPerformance Motorsports
Loperformance Motorsports
LoPerformance Motorsports's Avatar
Drives: 2011 2LT
Change the stock Backup/Reverse light bulbs to LED's
First let me say that this is not to take away from any venders on this site!!! This is just a DIY project that I thought worked out well for me. If yo want to change the look of your reverse lights. I know these are nothing like the ones that company's like AAC...ect,sells.
I was putting in my Rapid Fire taillights and decided to try a bulb change on the reverse lights. After taking a look, the bulb twists out just like any other bulb socket does.
I had a few LED/SMD lights, that are the same as a 194,168...ect bulb. So, I took the white base off it and had the leads exposed. After looking at the stock bulb, I started pulling the bulb out of the bulb socket. In the pics you will see that the bulbs are the same dia/length. worked the bulb leads into the socket, with it plugged to the wiring harness, worked like a charm. I now have brighter and whiter lights than come stock. The LED's had 5 SMD's per blub. I have a couple of light's ordered with 25 SMD's. I plan on changing to these after they come in. Just thought someone out there may want to do this.
Take note, you have to have the bulb socket plugged into the wiring harness, the leads on the LED/SMD bolb are small and bend easy. But, will set in the same base area as the stock bulb. I did put a small spot or two of silicone on the base of the socket where the light snaps in. Just to make sure it was secure. Good Luck!!
LoPerformance Motorsports is offline   Reply With Quote
Old 06-06-2012, 09:50 PM   #2
Drives: 2011 2LT
more pics
Old 06-06-2012, 09:50 PM   #3
BlackIce1066
Black Ice
BlackIce1066's Avatar
Drives: 2SS/RS Black w/ silver ice stripes
Hmmmmm very interesting. Nice job.
I see what you did now.
BlackIce1066 is offline   Reply With Quote
Old 06-06-2012, 09:55 PM   #4
Drives: 2011 2LT
I found the on ebay, but some of the venders here may have LED's that will work. The Japan LED's are junk. German made ones are the best!!! Or USA brands,for sure.
Old 06-07-2012, 09:58 AM   #5
BlackIce1066
Black Ice
I just realized I have a couple of LED's that were going to be for my license plate. I think I will have to try this.
Thanks
Old 06-07-2012, 10:06 AM   #6
Drives: 2011 2LT
Just remember that LED's are lead sensitive.
Old 06-07-2012, 10:51 AM   #7
Drives: '20 Corvette Stingray
LoPerformance.....just a suggestion for the future, make sure the pictures you have taken are in focus and people can actually see the detail you are trying to show them. The top and the last 2 are so blurry you might as well delete them. I'm just sayin.....
Old 06-07-2012, 11:42 AM   #8
Agent WD-40
Agent WD-40's Avatar
Drives: 2010 Camaro SS
Cool idea. How does the light output compare to stock?
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete
Roto-Fab Intake
Stainless Works 1 7/8" Long Tube Headers
Corsa Exhaust
Agent WD-40 is offline   Reply With Quote
Old 06-07-2012, 12:05 PM   #9
looking at the pictures he posted, his upgrade shows they put out a LOT more light. picture #2 is stock, Pic #3 is the upgrade.
Old 06-07-2012, 01:02 PM   #10
OldJedi
Use the Force
OldJedi's Avatar
Drives: 2015 Corvette Z51, 2018 Porsche GTS
Send a message via AIM to OldJedi
Is there a commercially made LED bulb that would be an exact replacement for the factory bulb without having to dissect the factory bulb holder?
Walk softly, carry a light saber and drive a ZL1!
OldJedi is offline   Reply With Quote
Old 06-07-2012, 05:01 PM   #11
Drives: 2011 2LT
I checked and there is no listing for a bulb. Oreilly's, autozone,...ect.
Old 06-07-2012, 05:13 PM   #12
iKeablr
iKeablr's Avatar
Drives: Chevrolet Camaro 2011 RS 1LT
Go to eBay, you'll definitely find some there. For cheap too
Camaro 2011 VR 1LT RS - Prometheus Prime
|Leather Interior|Leather Door & Dash Trim|12" Subwoofer|Dash ABL|Plasma DRL|
iKeablr is offline   Reply With Quote
Old 06-07-2012, 06:44 PM   #13
Drives: 2011 2LT
(factory replacement bulbs) Yes there all kinds of LED's to chose from out there!!!
Old 06-09-2012, 11:07 PM   #14
LanMan08
Drives: 2010 RS
did you have to take the entire bumper off to replace these?
LanMan08 is offline   Reply With Quote
