02-26-2017, 02:22 PM | #1 |
Drives: 2012 ZL1 Join Date: Apr 2015
At what point is a BAP required?
Hey guys, I'm just putting a list of parts together and I've been searching this with no definitive answer. Here's my mod list
Rotofab CAI 2.55" upper , ported inlet SLP 1 3/4" long tubes, catless Colder plugs, 160 tstat Id850''s Afco HX, rotofab IC reservoir 10.4mm wires And once I get the injectors I will be getting a custom tune. Will I need a BAP? I don't plan on doing anymore mods than these, not a cam or anything. Will I be OK without a BAP ? Thanks guys
2012 ZL1 preproduction car #13 ROTO-FAB intake / IC reservoir , 2.85" upper , ported inlet |
02-26-2017, 03:55 PM | #2 |
Drives: ZL1 Convertible Auto Join Date: Apr 2015
There are different opinions about the exact point that a BAP is needed but with those mods I would say no. Most people agree that it's needed somewhere around a cam and 28% overdrive or 31% overdrive and stock cam and you will be at 18%
LS3 intake and throttle body, Huron Speed Products twin turbo with 6265 oil less turbos, and 3" header back, JRE smooth cam, ID1300, Fore dual 450lph pumps with MSD voltage booster, A6, 305/45/17 MT Street R
02-26-2017, 11:21 PM | #3 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
You need a BAP if your fuel pressure is falling. Check fuel pressure at WOT all the way to redline. If it doesn't hold 65 psi then you need a BAP.
Don't depend on anyone's advice on a forum. Check your fuel pressure.
Bryan 2018 ZL1 M6
02-27-2017, 05:41 AM | #4 |
Drives: Zl1 Join Date: Sep 2016
Can u plz explain more about this method? As I'm planning to a add a BAP to my build but shops have different opinions about this.
02-27-2017, 07:03 AM | #5 |
Drives: 2015 ZL1 Blue Velvet Metallic Join Date: Mar 2015
I think what Bryan is saying is you need to monitor your fuel pressure during WOT so you can determine if your fuel pressure is dropping below 65 psi. You'll need a gauge or tuner to monitor/record.
Roto-Fab CAI, ARH LT, SW 3" catback, JRE tune, Elite-2 CC, VMAX TB, Big Gulp, WW II relo, Lingenfelter S/C reservoir
02-27-2017, 07:50 AM | #6 |
Yep, you can log fuel pressure with HPTuners or another scan tool. Or get a fuel pressure gauge and duct tape it to the windshield at see what happens when you get close to redline. Safest way would be to watch it on a dyno.
Bryan 2018 ZL1 M6
02-27-2017, 08:06 AM | #7 | |
http://www.camaro5.com/forums/showthread.php?t=289332
Bryan 2018 ZL1 M6
02-27-2017, 09:32 AM | #8 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
Bryan is correct. The only way to know is by logging fuel pressure with a scan tool. FWIW mine was fine until I went over 628 rwhp. Once again, you need to monitor fuel pressure, but that is when I started having the issue.
02-27-2017, 10:14 AM | #9 |
Drives: 2013 ZL1 M6 Join Date: Oct 2014
If you do find you need a bap, I am in Ontario as well and I have a Kenne Bell I used for 3 months that will be coming off. It will save you some money buying from the states
02-27-2017, 12:40 PM | #10 | |
Thanks for all the info guys!
02-27-2017, 01:49 PM | #11 |
ZL1 Pilot
The JMS unit is plug N play. It's what I use. It uses an inline harness for your throttle pedal. Simply run the wiring under the carpet to the trunk. I mounted mine in the battery area. You can set it to activate at whatever throttle pedal voltage you like.
GP Tuning 2.5 Cam, RPS Carbon Twin Clutch, Ported Blower, Kook's Headers, Cold Air Inductions CAI, ID850's, 9.17 Lower, 2.5 Upper, JMS BAP, Pedders Front Radius Arm Inserts, Whiteline Subframe Inserts, Tuned by me with HP Tuners Idle Clip Link...........https://www.youtube.com/watch?v=gTL8S9eHwbs |
02-27-2017, 02:52 PM | #12 | |
One of the shops here in UAE recommended that I buy one, the other shop said no way that u will need it and if u end up installing one it will damage my fuel pump in the futur , what do u think? Have u heard of such a failing fuel pump due to using BAP? |
02-27-2017, 09:21 PM | #13 | |
Bryan 2018 ZL1 M6
02-28-2017, 02:37 PM | #14 |
