05-01-2016, 07:17 AM | #15 | |
Drives: 2012 ZL1 Join Date: Nov 2015
Thanks, Mike |
05-01-2016, 07:39 AM | #16 | |
Drives: 2013 ZL1 M6 Join Date: Oct 2014
Ya I will ask him to email them to you, that's all I really want to know is what the cause was |
05-01-2016, 08:01 AM | #17 |
05-01-2016, 08:05 AM | #18 |
I don't recall reading about anyone else that has spun a main bearing ?
Doesn't mean it didn't or that you can't, but I don't think it's all that common in our LSA? |
05-01-2016, 08:09 AM | #19 | |
That's what I said seems like there's tons of guys with 750+ and haven't hurt anything then I'm at about 650 and that happens |
05-01-2016, 08:11 AM | #20 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
It's not common, but certainly not that unusual on highly modded cars. You see it more with the V guys simply because they mod more and the car has been around longer. Normally it starts with lower than normal oil pressure and gets worse from there. The fact that his motor seized up points to a catastrophic failure, but the only way to know is to tear down it for inspection.
05-01-2016, 10:08 AM | #21 |
America FVCK Yeah!
Drives: 2021 ZL1 1LE A10 Join Date: Mar 2013
The biggies in the V's are:
1) Loss of oil pressure - BOOM 2) Clogged cats, overheats engine - BOOM 3) Lean tune #7, #8 failure - BOOM (personally happened to me) 4) Not upgrading the trunions with cam install - potential BOOM |
05-01-2016, 12:45 PM | #22 | |
Motor will be out by Tuesday and I'll have a better update, tuner said you can't see oil pressure from the logs but that it wasn't low |
05-01-2016, 12:47 PM | #23 |
05-01-2016, 12:50 PM | #24 |
That's what I didn't understand but he said it didn't. He said there was 0 knock. I asked him to email the log he said he would cause he has nothing to hide and that you wouldn't be able to tell anything from the log |
05-01-2016, 02:12 PM | #25 |
05-01-2016, 06:46 PM | #26 |
Drives: 60's Muscle Join Date: Sep 2012
05-01-2016, 09:01 PM | #27 |
Could be possibly a spun rod bearing rather than a main since from what I read in the 1st post, he had new rods installed?
Always suspect the things that have changed. |
05-01-2016, 09:06 PM | #28 |
