03-13-2024, 06:10 AM | #15 | |
Drives: 1977 Pontiac Trans Am Join Date: Oct 2019
03-13-2024, 09:45 AM | #16 | ||
03-14-2024, 02:32 AM | #17 |
Drives: 2023 ZL1 - 1969 SS396 Join Date: Sep 2022
I am not talking about any existing hardware either. I am talking about adding it to the aftermarket device, to include it so it comes with the Garmin. It would be placed on dash to project it to the windshield, and also show the data out the front. The existing HUD would remain as is. Sorry if I'm thinking way out there, lol.....
2023 Code ZL1 1AL37 - Track Pack PPF
1969 Code X66 SS396 - RS Conversion - Holley Terminator TB w/ HP ECU EFI - TKO600 - 3.73 Posi. |
03-14-2024, 08:54 PM | #18 |
Drives: 22 ZL1 M6 Join Date: Oct 2018
Sold: '17 m6 2SS [arctic blue]
Current: '22 m6 zl1 [vivid orange] |
04-04-2024, 01:44 PM | #19 |
Still not at liberty to confirm or deny there are any new products in the pipeline
But if there were, it would probably not be available until Q1 or Q2 next year. Also cannot confirm or deny Can bus interface availability I'll keep you guys posted on other things I cannot confirm or deny as they come along
04-04-2024, 07:21 PM | #20 | |
04-04-2024, 10:14 PM | #21 | |
Drives: 2020 SS 1LE Join Date: Aug 2020
04-04-2024, 10:29 PM | #22 |
Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
Personally, for the $1000 price point, I feel the Garmin is absolute trash. Absolute trash.
I've researched this heavily and the closest thing you will get to the Cosworth PDR system is the SmartyCam setup combined with the Aim Solo 2DL (data logging capability) ==AND== using an add-on such as the the kit found at the following link to get tire pressure and tire temp wheel data: https://trailbrake.com/tire-tpms/ This setup total could cost you approximately $2,000-$2,500 (https://www.aimtechnologies.com/smar...ouble-bracket/) The downside is that the Race Studio Software that is needed to understand the data is NOT user friendly. I work in IT and it is an absolute nightmare to use for the uninitiated. The good part of the smartycam aim solo2 DL combo is that the camera will start recording as soon as the GPS picks up movement. No more reaching for the button to turn the camera on and off. No more synching the data overlay in the videos either. It does it all for you. |
04-15-2024, 07:19 AM | #23 |
sooo...Not having PDR on my ZL1 and being a novice myself, I'm looking for input as to what kind of data you guys would like to see from the CAN bus in an aftermarket system. I'm certain the design team (If in fact there is a design team) is aware of what is required, but I'm looking to ensure all the bases are covered. So far I have:
speed rpm throttle braking steering angle lateral Gs longitudinal Gs gear selection tire pressure tire temperature individual wheel speed suspension displacement yaw outdoor air temperature Is there anything else that might be useful e.g., PTM mode ? e-diff info, etc.? Thanks!
04-15-2024, 03:11 PM | #24 | |
Drives: broken Join Date: Aug 2009
eLSD lockup % Oil pressure Oil temp Intake air temp Coolant temp Trans temp Yaw rate of change Roll Roll rate of change Being able to pull any other data of the CANbus, run scripts, etc would also be sweet (really, enabling everything that Autosport Labs has on the Race Capture Track, adding video, and providing a better interface would be ideal).
clyde
Team WTF?! what are you gonna do? :dunno: |
04-15-2024, 11:13 PM | #25 | |
Drives: 2022 Rapid Blue ZL1 Join Date: Feb 2022
Fuel pressure (High and low side) PTM mode MAT2 temperature (or IAT3 on some gauges) Ethanol % for us tuned guys
2022 M6 Rapid Blue ZL1
Performance: Kong X-Port OEM blower, 1 7/8" TSP headers (Polydyn coated), Corsa Intake/X-pipe/NPP Exhaust, LT5 95MM TB, DSX FlexFuel sensor, Dedicated Motorsports inline fuel filter, Katech Dual fuel pump, WeaponX Boost freeze chiller, WeaponX center and aux HX, PWR oil cooler, and Elite E-2X catch can. Tuned by Pat G 731 WHP on a Mustang Dyno. Suspension/Brakes: Eibach lowering springs, Vorshlag camber plates, Full SPL rear control arms, DSC Sport suspension controller, Blackwing F/R brake cooling ducts. |
04-16-2024, 07:04 AM | #26 |
good input guys. Thanks. Keep 'em comin'!
04-16-2024, 07:10 AM | #27 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
I'd also reiterate oil pressure, and temperature. Maybe Trans Temp as well.
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
04-18-2024, 08:41 AM | #28 |
Drives: 2023 2SS 1LE Join Date: Jul 2023
Can Garmin add a function to add "open tracks or point to point tracks"? aka autocross, hill climb, drag strip etc...
