10-25-2021, 09:58 PM | #1 |
Drives: Chevrolet camauro v6 Join Date: Oct 2021
2014 Chevrolet Camaro LS v6 battery issues.
My Camaro has been having re occurring battery issues. The car after a couple hours of sitting drops voltage to battery saver mode and when I get in the car I can leave the key in and the volts start to increase enough for it to start, then the voltage goes back to normal after car has been started.
Brief History: I have had this car for about 10 months and in the past couple months I have replaced the alternator (800$) twice as well as the battery. there has been done some aftermarket stuff done but these things has been going on for a while now even before the installations. What was done: new touch screen radio professionally installed and two subs with an amp the amp has a fuse holder so it should be protecting the battery from any damage. etc.: 105,000 miles, no check engine ask many any additional questions |
10-26-2021, 12:34 AM | #2 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Had some tranny work done to one of vehicles. For some reason, they removed my remote wire from the ignition switched fuse to another one. Thus the amps and crossover stayed on. Bought a new battery since it was old. But was still dying. I used to install systems. Professional doesn't always yield professional results. Today's charging systems are really technical. Eating 2 alternators seems like the system was not designed properly. A fuse isn't really going to do much to protect anything, other than high current draw. What are the amps and speakers?
10-26-2021, 06:38 AM | #3 |
Drives: 2010 LS Join Date: Feb 2021
Most of the time, the radios are installed (wired) incorrectly.
You need to do a current draw test, and pull fuses one at a time, to see when the load drops. You pull the fuse, look at the meter, then put it back in, one at a time. |
